IP doesn't seem to change
frogman
Post by frogman » Sun Jul 26, 2020 2:34 am
Hello, It says I'm connected to the VPN gate but nothing seems to change. Running the ipconfig just shows my actual ip, and other ip checkers do the same. I've tried reinstalling the vpn adapter, I've disabled all my antivirus programs, and I've reinstalled vpn gate multiple times to no avail. The only thing that somewhat works is using hosts with very few active sessions, but even then it will only seem to bypass some ip checkers and not others, and the ipconfig still shows my real address. If anyone could help I would really appreciate it.
freeroute
Re: IP doesn't seem to change
Post by freeroute » Sat Aug 08, 2020 7:28 am
I am find the same problem.
Used some websites to test my IP,could not to change to VPN address,need to check the problem and upgrade softether vpn.
https://lcx.cc/post/4595/
IP 定位 逆向追踪溯源访客真实身份 调查取证
https://lcx.cc/post/4490/
JS绕过代理、VPN获取真实IP及内网IP,逆向追踪
https://lcx.cc/post/3422/
中国电信ADSL宽带信息泄露,可查任意IP对应的宽带账号,电话号码,上门砍人
Hope upgrade support WireGuard technical,could used 256bit encryption,thank you!
