hello, i have a minecraft server on my computer that i would like to leave online without using the hamachi method, i already tried to contact my internet provider but they don't care and they don't support me and the attendants don't understand me nor refer me to specialists.
i would like to know if softether has something similar to create a firewall tunnel skip bypass or some other vpn software has something to do that. i have tried several vpn software minus some as a freelan that i have not been able to configure or disable the requirement for digital certificates or do not work.
I can manually connect to the softether and create 1 proxy for a dhcp created by softether and then do what I want, however I want to do it automatically because I also don't know what the CPU cost is to test 65563 time entries in time instead of responding to just one event.
I already tried to use openvpn and use the script they instruct to bridge in linux, but excluding redhat and windows, all versions of linux ubuntu 16 18, hundred 7.8 and debian 9 10 when using the command to create bridge " brctrl add br0 "and" brctrl addif eth0 "it turns off the internet and it is not possible to turn it on again even by turning it off and on before and using other restart commands and scripts (/etc/network/if-down.d/ or etc / sysconfig / network-scripts / ifcfg-eth0) such as ifup and ifdown eth0 or ens4 (olds linux version in google cloud).
and I don’t want to pay for redhat or windows, but use the Google Cloud vm always free with 2Gbps that I could use as a firewall bypass and ddos protection with an IP bandwidth limit using wondershaper or "tc qdisc add dev eth0 root tbf rate 1024kbit latency 50ms burst 1540 "
