Hello World,
When I connect to the SoftEther VPN I lose access to my local LAN. For example I have a host with IP 10.1.1.2 attempting to RDP to host 10.1.1.3. This works perfectly until I connect to the SoftEther VPN.
On other VPN solutions I was able to split tunnel and connect to the VPN allow all outbound traffic to traverse the VPN and still maintain access to my local LAN.
Is it possible to connect to SoftEther, route internet traffic through the tunnel and still keep access to my local LAN to devices that are on the same subnet as the local LAN.
Thanks for all responses.
						No LAN Access On VPN
				bobbydigital
Re: No LAN Access On VPN
Hello World,
Please disregard. I figured out the issue. Only required a simple route add. Most of the other VPN solutions i've used in the past had an option for like split tunneling or allow local LAN.
Anywho. It's fixed. Hope this will help the next person that may experience this issue or something similar.
				frak
Can you explain exactly how to operate it
