Specific servers cannot be manually added (Error code 1)
Aeyeucgh
Post by Aeyeucgh » Sat May 15, 2021 11:54 pm
Hello
I noticed that whenever a server doesn't have its TCP port number listed in the plugin, it cannot be manually configured in Softether. Even if I go to the VPN Gate homepage and find the UDP port number, it always returns "Error code 1". Connecting through the VPN Gate plugin, however, still works as expected. Is this intentional behaviour?
PS: it works just fine for servers that have their port numbers displayed (using VPNGATE Hub and "vpn" in anonymous auth), regardless of whether I'm connecting through the plugin or if it's been manually added. This problem only seems to happen for the servers that don't have their TCP ports displayed.
eddiewu
Re: Specific servers cannot be manually added (Error code 1)
Post by eddiewu » Sun May 16, 2021 1:19 pm
Change the server hostname from xxx.opengw.net to xxx.softether.net and try again
Port doesn't matter but do not disable nat-t
