IPV6 Problem
Locked
akoxiwalay
IPV6 Problem
Post by akoxiwalay » Sat Mar 05, 2022 10:09 am
I just notice a problem in IPV6. We use IPV6 now in this region of the world. when I connect to a server and goto whatismyipdotcomit tells you that your IP was change but when you goto whatismyipaddressdotcom it will tell you your IPV6 which is your real IP and Location so we are not really protected using vpngate servers.
the problem is all the configs in here only route/mask/change your IPV4 but your IPV6 still expose. So the thing is as for me I dont wanna block my IPV6 I wanna mask it as well, any solution for this admin?
thanks!
eddiewu
Re: IPV6 Problem
Post by eddiewu » Sat Mar 05, 2022 10:39 am
The IPv6 routing management feature is absent in the standard version client. You can download the latest developer version installer here.
https://dev.azure.com/SoftEther-VPN/Sof ... dArtifacts
eddiewu
Re: IPV6 Problem
Post by eddiewu » Sat Mar 05, 2022 10:41 am
Forgot to mention that developer version doesn't support VPN gate.
If you are must use vpn gate, just disable IPv6.
Locked
