SoftEther doesn't work on Windows 10 laptop
				windows10xd
I installed SoftEther on Windows 10 notebook, then I connected to VPN and all is okay in SoftEther, but not working. My IP address in browser is still original. I'm connected to SoftEther, but this doesn't work. IP address is still same. When I used Softether on Windows 7, all was ok.
				polly
Re: SoftEther doesn't work on Windows 10 laptop
are you already use the others method that you use. Can you try using other than software try using SSL-VPN Connect guide, OpenVPN Config file for example, or MS-SSTP Connect guide
