mac issue
sairam
mac issue
Post by sairam » Mon Mar 25, 2019 3:06 pm
Hi ,
I created a vpn server in aws cloud and it working fine in windows .for mac, if we are connecting through l2tp it show vpn connected. But if want to access the remote servers it not allowing to connect . but in the vpnserver logs it show connected . if we go to the terminal if i ping the normal sites it is working if want to use remote server it shows (request timeout for icmp_seq). can pls know whether any firewalls are blocking.
Thanks
Sai Ram
