I want only the browser traffic to get routed through VPN
shanghai
Post by shanghai » Wed Jul 24, 2013 5:52 pm
Is there any way to do this? I don't want my Skype or torrent downloads go through the VPN as well, only my browsing. (I use Firefox)
parkycai
Re: I want only the browser traffic to get routed through VP
Post by parkycai » Thu Jul 25, 2013 12:18 am
Here's a work around: install VPN in a virtual machine and browse in it.
NYITGuy
Post by NYITGuy » Wed Sep 18, 2013 1:13 am
Although sloppy, you could find the bank of server ip's for Skype and then force a persistent route in the routing table so they always use the local NIC not the VPN.
See Route Add command.
GerryB
Post by GerryB » Fri Sep 20, 2013 12:24 am
In that case all you need is a proxy server rather than a full VPN. SSH does it for you. Created the secure tunnel and offers SOCKS Proxy forwarding. Set the broweser then to use localhost:port as its proxy server.
SSH using Bitwsie tunnelier is simplest to set up on windows server and client or use MyEntunnel.
Gerry
