No IP address given by SoftEther VPN Client in Centos 5.9
kh_tsang
Re: No IP address given by SoftEther VPN Client in Centos 5.
Same problem on Fedora.
dnobori
You should activate Secure NAT Virtual DHCP function.
KevCar
But doesn't the secure NAT virtual DHCP end up handing out DHCP to your lan segment as well as your clients? Thats the problem I have had.
dnobori
you need also a DHCP client on the virtual network adapter.
on Windows, DHCP client is automatically working on any network adapters.
however, on Linux, you might need to activate DHCP client manually if you want to use DHCP.
dksill
> want to use DHCP.
HowTo?
> want to use DHCP.
HowTo?
dnobori
depends on your environment. traditionally most people use dhclient.
