Hi Authors!
I'm getting the error below while generating users account at HUB1 via Powershell until I stop it. This error appears after 16th user has been created. Please shed some light on this.
VPN Server/HUB1>UserCreate user14 /group: /realname: /note:
UserCreate command - Create User
vpncmd command - SoftEther VPN Command Line Management Utility
SoftEther VPN Command Line Management Utility (vpncmd command)
Version 2.00 Build 9387 (English)
Compiled 2013/09/16 12:45:42 by yagi at pc25
Copyright (c) SoftEther Project. All Rights Reserved.
Connection was established with VPN Server "localhost" (port 443).
You have administrator privileges for Virtual Hub 'HUB1' on the VPN Server.
VPN Server/HUB1>UserCreate user15 /group: /realname: /note:
Error occurred. (Error code: 2)
Protocol error occurred. Error was returned from the destination server.
Thank you advance.
Error while generating users
Ardy7201
Re: Error while generating users
sorry for offtopic. can you please add me on fb?
my email ardyshazril@yahoo.com
i need your advice
waiting for your email and fb add
i need your advice
inten
> i need your advice
Skype: ksimonenko@outlook.com
> i need your advice
inten
Dear SoftEther,
It looks like we have found the timeout between multiple "vpncmd /server /password /hub /cmd:UserCreate UsernameN" commands when we are able create more than 16 users while running the posh script. The timeout is approx 75 ms.
I have checked Windows 8/Windows Server 2012 R2 on different hardware but result is the same.
As for our opinion it is a disk write software problem. Could you please check yr code to understand what is wrong?
