Cloud Server Connection to LAN
wwillett
Post by wwillett » Tue Oct 22, 2013 1:06 am
I have a cloud server that I am connecting to my LAN. SoftEther Server set up on LAN machine. SoftEther Client running on Cloud Server. When I connect to the LAN I lose the ability to access the Cloud Server via its internet IP address. I can still access the Cloud Server from the LAN. I would like to be able to access the Cloud Server both ways at the same time. Is this possible?
inten
Re: Cloud Server Connection to LAN
Post by inten » Tue Oct 22, 2013 1:14 am
Looks like yr issue is routing.
Did you use this http://www.softether.org/4-docs/2-howto ... M_into_LAN model?
wwillett
Post by wwillett » Tue Oct 22, 2013 1:22 am
Yes that is the model that I followed. I do not know what I need to do on the server or the SoftEther client to allow the internet connection to continue to function when the VPN tunnel is connected. Any advice is greatly appreciated!
inten
Post by inten » Tue Oct 22, 2013 1:29 am
When the Cloud VM is connected to your LAN do you lose the ability to access the Cloud Server via its internet IP address from your network only or from public IP also?
wwillett
Post by wwillett » Tue Oct 22, 2013 2:47 am
I lose it from public IP. From the LAN I can connect, although I have to use the LAN IP address. I haven't tried to get to the internet address from within the LAN.
inten
Post by inten » Tue Oct 22, 2013 3:02 am
Can you show "route print" when the connection is established?
kh_tsang
Post by kh_tsang » Tue Oct 22, 2013 12:10 pm
Simply configure the network adapter of the client in the cloud. Set a static local IP and leave the default gateway empty.
wwillett
Post by wwillett » Mon Oct 28, 2013 10:41 am
Setting a static IP and leaving the gateway blank on the virtual adapter did the trick! Thanks!
