i have 2-5 vpn server with diffrent location server.
let say, in this picture, i have 25 user on the hub : http://prntscr.com/207bnm
so, i want the same 25user, in another server. how to import them?
Managing user on several server. How to import user
- Contact:
Re: Managing user on several server. How to import user
Hi.
You need a script :) That script will export them and import them back to all of your servers. Or you can use our VPN management solution that will be publicly available by the end of the year.
When you don't like the answer, change the question.
Cheers,
Team.
VPNHPanel.com
This account is not associated to SoftEther project.
Cheers,
Team.
VPNHPanel.com
inten wrote:
> Hi.
is it free? waiting your VPN management...
> Hi.
- Contact:
Ardy7201 wrote:
> inten wrote:
> > Hi.
Here is s small code to copy users from one server to another. But you cannot copy passwords, again you need a management solution.
$SourceServer = "From Server IP"
$SourceHub = "FROM HUB"
$SourcePassword = "FROM HUB PASSWORD"
$DestServer = "To Server IP"
$DestHub = "DESTINATION HUB"
$DestPassword = "DESTINATION HUB PASSWORD"
$result = Invoke-Expression -command "vpncmd /server $SourceServer /hub:$SourceHub /password:$SourcePassword /cmd:UserList"
$regex = new-object System.Text.RegularExpressions.Regex("User Name\s*\|\s*(.*?)\s")
foreach($match in $regex.Matches($result))
$username = $match.Groups[1].Value
$result = Invoke-Expression -command "vpncmd /server $DestServer /hub:$DestHub /password:$DestPassword /cmd:UserCreate $username /group: /realname: /note:"
Write-Host $result
Write-Host
> inten wrote:
> > Hi.
Write-Host $result
Write-Host
Cheers,
Team.
VPNHPanel.com
Cheers,
Team.
VPNHPanel.com
