Problem Installing
auroria
Problem Installing
Post by auroria » Sat Nov 02, 2013 1:57 am
Ok so I am not computer savvy at all but i'm playing a mmorpg from europe and the servers are based in montreal, canada...this is resulting in lag/delays. A few people mentioned SoftEther and said it worked for them and so I decided to give it a go, I downloaded the zip file and extracted it, I ran the installer as directed in the set-up process and it seems to work fine until maybe a minute or so into 'The setup of SoftEther VPN Client is in process please wait' part - then I get a box pop-up on my screen saying 'SoftEther VPN has stopped working'.
inten
Re: Problem Installing
Post by inten » Sat Nov 02, 2013 2:01 am
OK, what is your problem?
auroria
Post by auroria » Sat Nov 02, 2013 2:18 am
That it won't install...
"I downloaded the zip file and extracted it, I ran the installer as directed in the set-up process and it seems to work fine until maybe a minute or so into 'The setup of SoftEther VPN Client is in process please wait' part - then I get a box pop-up on my screen saying 'SoftEther VPN has stopped working'."
when the box pops up that it's not working...that's it, you have to click 'close program' and it does nothing, it's not installed and it doesn't finish installing.
inten
Post by inten » Sat Nov 02, 2013 2:36 am
What is your OS?
auroria
Post by auroria » Sat Nov 02, 2013 2:18 pm
inten wrote:
> What is your OS?
Windows 7
