SoftEther use a proxy server to connect on the Internet
hosein.zarei
Post by hosein.zarei » Sun Nov 03, 2013 7:37 pm
Hi everyone
I am using SoftEther to make a VPN network. I installed SoftEther on my computer. My computer uses a proxy server to connect the Internet. My VPN users that connected to SoftEther, They can't connect to the Internet because I didn't have set a proxy server for SoftEther.
How can I tell SoftEther to use a proxy server for connect to the Internet? Did anyone have a solution for my problem? It's a really necessary and I need it.
Thanks for your attention.
inten
Re: SoftEther use a proxy server to connect on the Internet
Post by inten » Sun Nov 03, 2013 11:49 pm
You can't.
hosein.zarei
Post by hosein.zarei » Mon Nov 04, 2013 5:56 am
Really?
inten
Post by inten » Mon Nov 04, 2013 6:04 am
Why not?
kh_tsang
Post by kh_tsang » Tue Nov 05, 2013 9:20 am
Using a network connection which requires using proxy is not a good idea to use it for setting up a VPN Server.
inten
Post by inten » Tue Nov 05, 2013 9:55 am
Could you please explain why it's not a good idea?
kh_tsang
Post by kh_tsang » Tue Nov 05, 2013 1:25 pm
Because a lot of softwares using network do not support proxy. A lot of softwares may not be used.
A temporary solution is to ask the user to configure the proxy by thenselves using the address provided by you. However, the long term solution would be replacing with an internet connection which proxy is not required
