How to disable logs
				inten
Re: How to disable logs
use vpncmd as described here http://www.softether.org/4-docs/1-manua ... ng_Service
				soyrme
I have the same issue with the gui where I can't change the "Log Save Setting" button on the "Manage Virtual Hub" option.  The Log Save Setting button is greyed out.
Is there any way to enable this in the gui so it can be changed there instead of going to the command line?
Thanks
Thanks
