Redirect traffic to local proxy
Hi all,
I have successfully set up SE on Ubuntu 13 server. Runs great. I am interested in diverting my VPN traffic to Ziproxy which is running on 127.0.0.1:8080
Please could someone guide me. Thanks in advance folks.
Cheers
Cheers
- Contact:
Re: Redirect traffic to local proxy
Which interface you want to redirect traffic from?
When you don't like the answer, change the question.
Cheers,
Team.
VPNHPanel.com
This account is not associated to SoftEther project.
Cheers,
Team.
VPNHPanel.com
Thanks for the reply. I am using a local bridge called tap_soft and I want to redirect/forward to localhost port 8080.
I followed an article from here http://linc01n.github.io/blog/2013/05/1 ... al-bridge/
- Contact:
Does ziproxy support transparent proxy mode?
Anyway try this but change proxy port number:
iptables -t nat -A PREROUTING -i tap_soft -p tcp --dport 80 -j REDIRECT --to-port PROXY_PORT
Cheers,
Team.
VPNHPanel.com
Cheers,
Team.
VPNHPanel.com
Works perfect my friend. Many thanks.
I have one request.
Right now ziproxy is listing to my external IP. I want to redirect from tap_soft to my localhost 8080. Ziproxy is running on transparent mode.
Thanks in advance.
I have one request.
Thanks in advance.
- Contact:
Do not understand what you want. Sorry. More detailed please.
Ok. I have two interface. Eth0 and tap_soft
Right now ziproxy is listening on the eth0, this is also the external ip
i can configure ziproxy to listen on 127.0.0.1:8080
So I want to divert traffic from tap_soft to my localhost:8080
If someone scans my external ip, they will see port 8080 is open and accepting connection.
iptables -t nat -A PREROUTING -i tap_soft -p tcp --dport 80 -j REDIRECT --to-port 8080 works perfect as ziproxy is listening on external IP.
I am looking for something like iptables -t nat -A PREROUTING -i tap_soft -p tcp --dport 80 -j REDIRECT --to-port 127.0.0.1:8080
cheers
cheers
- Contact:
Did you try to configure proxy on tap interface?
- Contact:
I have just tried, everything is as I described ;)
Cool I will give it a short
Thanks for taking time to help me out. It works perfect. Looking forward to your management solution.
Cheers
Cheers
