Stuck getting L2TP/IPSec working on Raspberry Pi
Capt.Insano
I have googled loads and read many articles on this topic but I cannot get my Windows 10 PC or Android phone to connect via L2TP/IPSec to my Raspberry Pi running SoftEther.
I have read through
https://www.softether.org/4-docs/2-howt ... VPN_Server
multiple times but I still cannot get a connection.
System:
Raspberry Pi 3 running Hassbian (Rasbian distro for HomeAssistant home automation software)
SoftEther Version: softether-vpnserver-v4.22-9634-beta-2016.11.27-linux-arm_eabi-32bit
I have used the windows management client to set a DDNS Hostname, I also ticked "Enable L2TP Server Function (L2TP over IPSec)" and I have set an IPSec Pre-Shared Key and I created a user with password authentication.
I did not change any other settings on the SoftEther server
I have also forwarded all of the following ports (TCP/UDP) on my router to my Raspberry Pi : 50, 500, 1701, 1723, 4500
On my windows 10 client I have used the following settings:
Server Name or Address: xxxxxxx.softether.net (DDNS setup during configuration)
Username: (username created above)
Password (password created above)
I changed adaptor settings and set security to L2TP/IPSec and I set the correct Pre-Shared Key as above.
I followed the android settings from here : https://www.softether.org/4-docs/2-howt ... ient_Setup
With either my Windows 10 PC or Android Phone I get no connection.
Windows PC:
Spends a lot of time on "Completing the connection" and then says "A connection to the remote computer could not be established. You might need to change the network settings for the connection"
Android Phone:
Just says "Unsuccessful"
In troubleshooting, I even changed the server address in the clients L2TP settings to be the local address of the raspberry pi but it still would not connect.
Are my ports right, Is there something I need to do with the raspberry pi iptables or is there something else I am missing?
Any help much appreciated.
I have read through
System:
Windows PC:
Android Phone:
Capt.Insano
Re: Stuck getting L2TP/IPSec working on Raspberry Pi
Bump (due to amount of spam on these boards.)
Thanks again for any help
Capt.Insano
Bump again, (these boards are really full of spam!)
Any help at all would be appreciated
KASCON11
Did you ever get any help with this issue? I am having the same issue on a Windows PC and was thinking to switch to a raspberry Pi install.
softy
I have Softether running on a RasPi2! Works perfectly!
But one issue took time to solve, maybe you have the same issue.
So I have Softether on a RasPi, fine, and I use Windows 10 (totally unrelated though). Of course it's way more convenient to use the Windows SE-VPN Server Manager, right?
You can make all changes from Windows conveniently and see them right away! Wrong!
There was my problem! You can NOT use SE-VPN Server Manager tool to make changes on a Linux server! That includes the RasPi.
You need to use a terminal software such as Putty and login to Softether and make the changes that way.
Use:
sudo /usr/local/vpnserver/vpncmd
And now check your settings. Maybe there you find your error.
Use:
triwaves
Not sure I agree with that, I use a win 10 machine with the server manager running to configure multiple remote RPi servers all the time. You can of course use SSH and command line but don't need to.
Another way I use on a Linux machine is to install SEVPN manager on the Linux machine via wine. It works just fine if you are at a display on that machine or if you want to SSH in remotely.
Capt.Insano
@softy: All changes I made via the Windows based management app seem to have been added to the VPN config.
See VPN Config below:
########################## START LOGS ###################################
VPN Server>ConfigGet
ConfigGet command - Get the current configuration of the VPN Server
Config name: "vpn_server.config", Size: 14392
# Software Configuration File
# You may edit this file when the VPN Server / Client / Bridge program is not ru nning.
declare root
uint ConfigRevision 27
string Region AT
declare DDnsClient
bool Disabled false
byte Key xxxxxxxxxxxxxxxxxxxxxx=
string LocalHostname hassbian
string ProxyHostName $
uint ProxyPort 0
uint ProxyType 0
string ProxyUsername $
declare IPsec
bool EtherIP_IPsec false
string IPsec_Secret wellesley
string L2TP_DefaultHub VPN
bool L2TP_IPsec true
bool L2TP_Raw false
declare ListenerList
declare Listener0
bool DisableDos false
bool Enabled true
uint Port 443
declare Listener1
bool Enabled true
uint Port 992
declare Listener2
bool Enabled true
uint Port 1194
declare Listener3
bool Enabled true
uint Port 5555
declare LocalBridgeList
bool DoNotDisableOffloading false
declare LocalBridge0
string DeviceName wlan0
string HubName VPN
bool LimitBroadcast false
bool MonitorMode false
bool NoPromiscuousMode false
bool TapMode false
declare ServerConfiguration
bool AcceptOnlyTls true
uint AutoSaveConfigSpan 300
string CipherName DES-CBC3-SHA
uint CurrentBuild 9634
bool DisableDosProction false
bool DisableOpenVPNServer true
bool DisableSSTPServer true
bool DontBackupConfig false
bool EnableVpnAzure false
bool EnableVpnOverDns false
bool EnableVpnOverIcmp false
byte HashedPassword 7mnzzB+ZLx8ESM+NkDJtgzCUYBI=
uint KeepConnectInterval 50
uint KeepConnectPort 80
uint KeepConnectProtocol 1
uint MaxConcurrentDnsClientThreads 64
uint MaxConnectionsPerIP 256
bool NoLinuxArpFilter false
bool NoSendSignature false
string OpenVPNDefaultClientOption dev-type$20tun,link-mtu$201500 ,tun-mtu$201500,cipher$20AES-128-CBC,auth$20SHA1,keysize$20128,key-method$202,tl s-client
bool SaveDebugLog false
byte ServerCert xxxxxxxxxxxxxxxxxxxxxx
xxxxxxxxxxxxxxxxxxxxxxxxxx
byte ServerKey xxxxxxxxxxxxxxxxxxxxxxxxxx
uint ServerLogSwitchType 4
uint ServerType 0
bool Tls_Disable1_0 false
bool Tls_Disable1_1 false
bool Tls_Disable1_2 false
bool UseKeepConnect true
bool UseWebTimePage false
bool UseWebUI false
declare GlobalParams
uint FIFO_BUDGET 1000000
uint MAX_BUFFERING_PACKET_SIZE 480000
uint MAX_HUB_LINKS 1024
uint MAX_IP_TABLES 65536
uint MAX_MAC_TABLES 65536
uint MAX_SEND_SOCKET_QUEUE_SIZE 320000
uint MAX_STORED_QUEUE_NUM 384
uint MEM_FIFO_REALLOC_MEM_SIZE 65536
uint MIN_SEND_SOCKET_QUEUE_SIZE 80000
uint QUEUE_BUDGET 1024
uint SELECT_TIME 256
uint SELECT_TIME_FOR_NAT 30
uint STORM_CHECK_SPAN 500
declare ServerTraffic
declare RecvTraffic
uint64 BroadcastBytes 1469370844
uint64 BroadcastCount 19640549
uint64 UnicastBytes 2196415295
uint64 UnicastCount 8946767
declare SendTraffic
uint64 BroadcastBytes 71612
uint64 BroadcastCount 598
uint64 UnicastBytes 58024312
uint64 UnicastCount 1233268
declare SyslogSettings
string HostName $
uint Port 514
uint SaveType 0
declare VirtualHUB
declare VPN
uint64 CreatedTime 1505284751651
byte HashedPassword xxxxxxxxxxxxxxxxxxxxxxxxxx
uint64 LastCommTime 1506941371097
uint64 LastLoginTime 1505289831639
uint NumLogin 0
bool Online true
string RadiusRealm $
uint RadiusRetryInterval 0
uint RadiusServerPort 1812
string RadiusSuffixFilter $
byte SecurePassword xxxxxxxxxxxxxxxxxxxxxxxxxx
uint Type 0
declare AccessList
declare AdminOption
uint deny_bridge 0
uint deny_empty_password 0
uint deny_qos 0
uint deny_routing 0
uint max_accesslists 0
uint max_bitrates_download 0
uint max_bitrates_upload 0
uint max_groups 0
uint max_sessions 0
uint max_sessions_bridge 0
uint max_sessions_client 0
uint max_users 0
uint no_cascade 0
uint no_change_access_list 0
uint no_change_cert_list 0
uint no_change_crl_list 0
uint no_change_groups 0
uint no_change_log_config 0
uint no_change_msg 0
uint no_change_users 0
uint no_delete_iptable 0
uint no_delete_mactable 0
uint no_disconnect_session 0
uint no_enum_session 0
uint no_offline 0
uint no_online 0
uint no_query_session 0
uint no_read_log_file 0
uint no_securenat 0
uint no_securenat_enablenat 0
declare CascadeList
declare LogSetting
uint PacketLogSwitchType 4
uint PACKET_LOG_ARP 0
uint PACKET_LOG_DHCP 1
uint PACKET_LOG_ETHERNET 0
uint PACKET_LOG_ICMP 0
uint PACKET_LOG_IP 0
uint PACKET_LOG_TCP 0
uint PACKET_LOG_TCP_CONN 1
uint PACKET_LOG_UDP 0
bool SavePacketLog true
bool SaveSecurityLog true
uint SecurityLogSwitchType 4
declare Message
declare Option
uint AdjustTcpMssValue 0
bool DisableHttpParsing false
bool DisableIPParsing false
bool DisableIpRawModeSecureNAT false
bool FilterBPDU false
bool FilterIPv4 false
bool FilterIPv6 false
bool FilterNonIP false
bool FilterOSPF false
bool FilterPPPoE false
bool ManageOnlyPrivateIP true
uint MaxSession 0
bool NoArpPolling false
bool NoEnum false
bool NoIpTable false
bool NoIPv4PacketLog false
bool NoIPv6AddrPolling false
bool NoIPv6PacketLog false
bool NoLookBPDUBridgeId false
bool NoMacAddressLog true
bool NoManageVlanId false
uint RequiredClientId 0
string VlanTypeId 0x8100
declare SecureNAT
bool Disabled true
bool SaveLog true
declare VirtualDhcpServer
string DhcpDomainName $
bool DhcpEnabled true
uint DhcpExpireTimeSpan 7200
string DhcpLeaseIPEnd 192.168.30.200
string DhcpLeaseIPStart 192.168.30.10
string DhcpPushRoutes $
declare VirtualHost
string VirtualHostIpSubnetMask 255.255.2 55.0
string VirtualHostMacAddress 00-AC-C4-39 -92-5F
declare VirtualRouter
bool NatEnabled true
uint NatMtu 1500
uint NatTcpTimeout 1800
uint NatUdpTimeout 60
declare CertList
declare CrlList
declare GroupList
declare IPAccessControlList
declare UserList
declare user
byte AuthNtLmSecureHash xxxxxxxxxxx
byte AuthPassword
xxxxxxxxxxxxxxxxx
uint AuthType 1
uint64 CreatedTime 1505284945866
uint64 ExpireTime 0
uint64 LastLoginTime 15052898316 39
string Note $
uint NumLogin 0
string RealName User
uint64 UpdatedTime 1505284945866
declare Traffic
declare RecvTraffic
uint64 Broadcast Bytes 67660
uint64 Broadcast Count 586
uint64 UnicastBy tes 0
uint64 UnicastCo unt 0
declare SendTraffic
uint64 Broadcast Bytes 3952
uint64 Broadcast Count 12
declare Traffic
declare RecvTraffic
declare SendTraffic
VPN Server>
########################## END LOGS ###################################
Any ideas?
declare root
string Region AT
declare DDnsClient
bool Disabled false
uint ProxyPort 0
uint ProxyType 0
declare IPsec
bool L2TP_Raw false
declare Listener0
bool Enabled true
uint Port 443
declare Listener1
bool Enabled true
uint Port 992
declare Listener2
bool Enabled true
uint Port 1194
declare Listener3
bool Enabled true
uint Port 5555
string HubName VPN
bool TapMode false
uint ServerType 0
bool UseWebUI false
declare RecvTraffic
declare SendTraffic
string HostName $
uint Port 514
uint SaveType 0
declare VirtualHUB
declare VPN
uint NumLogin 0
bool Online true
uint Type 0
declare AccessList
declare AdminOption
uint deny_bridge 0
uint deny_qos 0
uint deny_routing 0
uint max_groups 0
uint max_sessions 0
uint max_users 0
uint no_cascade 0
uint no_offline 0
uint no_online 0
uint no_securenat 0
declare CascadeList
declare LogSetting
declare Message
declare Option
uint MaxSession 0
bool NoEnum false
declare SecureNAT
bool Disabled true
bool SaveLog true
declare VirtualHost
uint NatMtu 1500
declare CertList
declare CrlList
declare GroupList
declare UserList
declare user
byte AuthPassword
xxxxxxxxxxxxxxxxx
uint AuthType 1
uint64 ExpireTime 0
string Note $
uint NumLogin 0
declare Traffic
declare RecvTraffic
declare SendTraffic
declare Traffic
declare RecvTraffic
declare SendTraffic
VPN Server>
Any ideas?
softy
Not sure I disagree with you. But I tried some time and it didn't work. Then I read somewhere (on the internet, so it can't be wrong, right?) that remote from Win ain't working, so I SSH to the RasPi and did the settings there - and it worked first try!
But maybe it was something unrelated.
PS: I wish somebody would do something about the SPAM issue here.
Could you show the server log when the connection failed?
