So the device I wanted to run softether on uses uclibc. When trying to compile softether, it was apparent that the exisiting libraries were compiled with (e)glibc.
So I compiled an openwrt toolchain based on eglibc, and I made a static binary, so that it doesn't have any external dependencies.
It seems to have compiled fine, and looks as if it will be functional. But when I transferred it to the router and run it, I get...
-- Alert: SoftEther VPN Kernel --
String Library Init Failed.
Please check your locale settings and iconv() libraries.
So I'm not sure what to do to get past this.
Re: String Library Init Failed.
I'm getting this error too.
https://github.com/el1n/OpenWRT-package ... r/issues/6
I am quoting el1n here
This problem occurs because not set LANG environment variable in OpenWrt.
If you want run softether binary in shell, you need set LANG environment variable.
e.g.
/usr/bin/env LANG=en_US.UTF-8 /usr/bin/vpnclient
I did append this command to init script but regarding this i forget write to README.MD.
