L2TP/IPSEC PSK Issue
novumav
Post by novumav » Wed Jan 22, 2014 10:24 pm
Hi All.
Hope you can help with this.
I'm trying to set up a few android devices and iPhone using L2TP/IPSEC PSK.
I've followed the online info but I'm having no luck. It just keeps saying unsuccessful.
I've noticed something though.
I have selected the user names etc as standard passwords. When i log on using my laptop selecting my log in, it only connects by using Radius or NT domain password setting.
I HAVE NOT SELECTED THIS AT ALL. I've been back on the server and I've made sure it only has the standard password selected. But alas, No luck and from a PC it's asking for radius or NT domain log in.
Can anyone help?
I'm not using secure NAT or anything. This is a direct link to the virtual hub.
Also, can I just check the forwarding route is 0.0.0.0/0. If not how do I find out what it should be? I haven't changed anything from the original install.
Thanks in advance.
Simon
mesa57
Re: L2TP/IPSEC PSK Issue
Post by mesa57 » Fri Jan 24, 2014 8:17 am
You're server hub should use secureNat OR be bridged to a local network adapter.
In the last case the client should get an ip address of the server's dhcp server on the network of the local network adapter.
novumav
Post by novumav » Fri Jan 24, 2014 9:31 am
It is all set up and working using the softether client. But using L2TP/IPSEC PSK doesn't.
Everything else works fine and gets the IP from my server on the network. However, the L2TP connection just doesn't work.
I only have the 1 connection in the softether server with 1 network bridge to the server.
Any further ideas?
Simon
Nazir
Post by Nazir » Tue Jan 28, 2014 11:34 am
I have the same problem.
I can log into my VPN using the softether client on Windows, but cannot make L2TP/IPSEC PSK from android.
I have also tried configuring the windows Client as per the tutorials online but no joy.
Nazir
Post by Nazir » Thu Jan 30, 2014 11:46 am
for now I am using OPENVPN-CONNECT app from OpenVPN of googles app store.
I know this isnt L2tP with ipsec, but android users can connect with this.
it will be great if a solution can be found for the l2tp issues that dont work
novumav
Post by novumav » Thu Jan 30, 2014 11:59 am
> work
Have you had to set up certificates for all users?
Nazir
Post by Nazir » Thu Jan 30, 2014 1:04 pm
username and password for authentication.
Hsec
Post by Hsec » Thu Mar 06, 2014 9:28 pm
I can connect to the server using my mobile (android), but no send/receive at all!
how could I find the reason?!
Post by thisjun » Mon Mar 10, 2014 6:58 am
Hi, Hsec
We need more information. We can't find problem.
Please see http://www.vpnusers.com/viewtopic.php?f=7&t=2790
Hsec
Post by Hsec » Mon Mar 24, 2014 2:29 pm
(It’s a virtual machine (ESXi base) on a dedicated server.)
I'm using this server as a gateway to internet.
1-
CentOs 6.5 X86_64
2-
eth0 Link encap:Ethernet HWaddr 00:50:56:A:B:C
inet addr: x.y.z.156 Bcast:x.y.z.159 Mask:255.255.255.240
inet6 addr: fe80::250:56ff:fe15:2282/64 Scope:Link
UP BROADCAST RUNNING PROMISC MULTICAST MTU:1500 Metric:1
RX packets:22227133 errors:0 dropped:0 overruns:0 frame:0
TX packets:24571584 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:10803056439 (10.0 GiB) TX bytes:12327220494 (11.4 GiB)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
UP LOOPBACK RUNNING MTU:16436 Metric:1
RX packets:2300 errors:0 dropped:0 overruns:0 frame:0
TX packets:2300 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:2143642 (2.0 MiB) TX bytes:2143642 (2.0 MiB)
3-
Linux SG156 2.6.32-431.el6.x86_64 #1 SMP Fri Nov 22 03:15:09 UTC 2013 x86_64 x86_64 x86_64 GNU/Linux
4-
Build 9423
5-
I don’t know what this question exactly mean
6-
As I already mentioned, the server is a virtual machine on a dedicated server. I don’t have any NAT or Firewall installed but, the Datacenter surely use firewall.
7-
I use SecureNAT for ease of use. I don’t want to config dhcp on my server. And I don’t know much about “Local Bridge function” and why I should use it.
8-
# Software Configuration File
# You can edit this file when the program is not working.
declare root
uint ConfigRevision 84
declare DDnsClient
bool Disabled false
byte Key sT+A3709ipdRS/*/lz3c=
string LocalHostname SG156
string ProxyHostName $
uint ProxyPort 0
uint ProxyType 0
string ProxyUsername $
declare IPsec
bool EtherIP_IPsec true
string IPsec_Secret *****
string L2TP_DefaultHub VPN
bool L2TP_IPsec true
bool L2TP_Raw true
declare ListenerList
declare Listener0
bool DisableDos false
bool Enabled true
uint Port 443
declare Listener1
bool Enabled true
uint Port 992
declare Listener2
bool Enabled true
uint Port 1194
declare Listener3
bool Enabled true
uint Port 5555
declare LocalBridgeList
declare ServerConfiguration
uint AutoSaveConfigSpan 300
string CipherName RC4-MD5
uint CurrentBuild 9423
bool DisableDosProction false
bool DisableOpenVPNServer false
bool DisableSSTPServer false
bool DontBackupConfig false
bool EnableVpnAzure false
bool EnableVpnOverDns false
bool EnableVpnOverIcmp false
byte HashedPassword **************************
uint KeepConnectInterval 50
uint KeepConnectPort 80
uint KeepConnectProtocol 1
uint MaxConnectionsPerIP 256
bool NoLinuxArpFilter false
bool NoSendSignature false
bool SaveDebugLog false
byte ServerCert */*/*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
byte ServerKey */*+*/bK0AlvF1tCdzfar2CxfOn84G10a/1YlqsQpkhM+y1TNS8zsr2wtL0J839bhQ6zye9dgc3UKDwu1DX3twVjCsAEmO9Lj0geU1YkPPSTs5bpmI55OmH9GNSIdQhQlZX/+zoKxB9+53LCpMQQOCbW2LEvVdPrbq7g6QDnFbQhIPdCFeBepeAeWg379oe7kGt0c5cdamxUdtqOM83G9X3A/TddSUe3zRfU+AZQoZjVqWTv2t9NFgtK4EVpdJ9WXNC2TzTHlwVayIlZcpmZDXjWYXoFmHHfwIDAQABAoIBAB2TC1+mT0J9j7iDl4hYF2XhM4+EVqVI5YIq2K+TQug0Dlp84Z8aSB0sKDVkCkUsyHEUTh443pTSrmqZZj+mJbff+QWECMYfscNh72CsD8LP6XwLPVgt39EfpqBmswdjxkhbLuJbjGA0P4prgtKXc0aG16C/lO63xEa5eCsFLYFaQa7QVg5GTNpnABjBjUJx00UgruNzwfOr146ZNX1Ggtl4wC5nlF2oa2V8pPHrAalOdeAUJMJNrpgo/V+L6Mfsw0T6H34s7I9k3CUEbqQ4sKRukx1oZCpGDLwkRv/Oe5UDFeCiaI8PspqCVArO6aYCzSbvfkc1/bXYGEDB7RmiP/ECgYEA2Mt1yevSB9NJOCduqGFD42a+r5sNjXHLXEihtjjqraxf89/bMlrZsS067K0794tqsEj1lj6tyWG1HbcDfIQ9bnCHJErMoJ+N5rHIv8hcvIwa0trBEXpuMmgGX0vsi87bOIiH05QFG/5KZer2ZHtok280lM9fUU7rvhA2N3Z6DecCgYEAzv5HsSGCgGamdBqr/6e9VGIrBlEzGdj5V48FN2TSIbFwyHJQAvuAwZMQe4OaVUEn+FjHiVki3ff8y4xrbnmqDSv83FK3BftVhrQwD04afKV+1FEINi//w8kdONkmARUh8dd0T3y9KHEcKZwJn1oIY0Q4FqwJZxgSjbtbjCVlVqkCgYEAo8Vvgc4np8mw8j63lXOEuXCQdFAJeOSR33Du2J0+i1xAUBa3m96NvQ6SCOEFAAfN3MYA4DMRTaQGEiCC/blYPum67WukEWL262M6Z8aQZ87fJJIkb3Oxc1qqFathUmw9pwNcuDSFd5Qt17gb0eR4J4hGjHPraZzY8YeFrXhO09kCgYBpXWaA893KHnZ8g1cqO+hUG+RqwsqQTbIer96n49pS7E/MuOOhoQRZhNLPDJ5y50fBUu+/KnBlLOaxdjj5c1Tsf4enXzNrCBTxDKeqIse4y0VULitP6f73WlhVp7OAuZEd2d6K16QyAeGkDJmZU+sRHJiwccIXiFlpbAWdwStkgQKBgQCrQ7ICagMZ/EOL/eLO3/i+lb3RrR7gieV70ci+4ViDzEK+rUjEL/awOSvqO8VKaJ/tlx7LwrluCZp1zE85Ly/P/vzuhFC9gIY/yJnW5f25X6EYGC7R4l0jNn4GEgDSP8mLi/kWBnzFxAWxGFZ9FhU8jQkCLEACVVn6vgnrztIpKQ==
uint ServerType 0
bool UseKeepConnect true
bool UseWebTimePage false
bool UseWebUI false
declare ServerTraffic
declare RecvTraffic
uint64 BroadcastBytes 128794138
uint64 BroadcastCount 1784265
uint64 UnicastBytes 11053143330
uint64 UnicastCount 23805341
declare SendTraffic
uint64 BroadcastBytes 89552638
uint64 BroadcastCount 916099
uint64 UnicastBytes 11046815257
uint64 UnicastCount 23892253
declare SyslogSettings
string HostName $
uint Port 0
uint SaveType 0
declare VirtualHUB
declare DEFAULT
uint64 CreatedTime 1393596623376
byte HashedPassword +*******************=
uint64 LastCommTime 1393596623361
uint64 LastLoginTime 1393596623361
uint NumLogin 0
bool Online true
uint RadiusRetryInterval 0
uint RadiusServerPort 1812
string RadiusSuffixFilter $
byte SecurePassword ****************************
uint Type 0
declare AccessList
declare AdminOption
uint deny_bridge 0
uint deny_empty_password 0
uint deny_qos 0
uint deny_routing 0
uint max_accesslists 0
uint max_bitrates_download 0
uint max_bitrates_upload 0
uint max_groups 0
uint max_sessions 0
uint max_sessions_bridge 0
uint max_sessions_client 0
uint max_users 0
uint no_cascade 0
uint no_change_access_list 0
uint no_change_cert_list 0
uint no_change_crl_list 0
uint no_change_groups 0
uint no_change_log_config 0
uint no_change_msg 0
uint no_change_users 0
uint no_delete_iptable 0
uint no_delete_mactable 0
uint no_disconnect_session 0
uint no_enum_session 0
uint no_offline 0
uint no_online 0
uint no_query_session 0
uint no_read_log_file 0
uint no_securenat 0
uint no_securenat_enablenat 0
declare CascadeList
declare LogSetting
uint PacketLogSwitchType 4
uint PACKET_LOG_ARP 0
uint PACKET_LOG_DHCP 1
uint PACKET_LOG_ETHERNET 0
uint PACKET_LOG_ICMP 0
uint PACKET_LOG_IP 0
uint PACKET_LOG_TCP 0
uint PACKET_LOG_TCP_CONN 1
uint PACKET_LOG_UDP 0
bool SavePacketLog true
bool SaveSecurityLog true
uint SecurityLogSwitchType 4
declare Message
declare Option
uint AdjustTcpMssValue 0
bool DisableHttpParsing false
bool DisableIPParsing false
bool FilterBPDU false
bool FilterIPv4 false
bool FilterIPv6 false
bool FilterNonIP false
bool FilterOSPF false
bool FilterPPPoE false
bool ManageOnlyPrivateIP true
uint MaxSession 0
bool NoArpPolling false
bool NoEnum false
bool NoIpTable false
bool NoIPv4PacketLog false
bool NoIPv6AddrPolling false
bool NoIPv6PacketLog false
bool NoLookBPDUBridgeId false
bool NoMacAddressLog true
bool NoManageVlanId false
uint RequiredClientId 0
string VlanTypeId 0x8100
declare SecureNAT
bool Disabled true
bool SaveLog true
declare VirtualDhcpServer
string DhcpDomainName $
bool DhcpEnabled true
uint DhcpExpireTimeSpan 7200
string DhcpLeaseIPEnd 192.168.30.200
string DhcpLeaseIPStart 192.168.30.10
declare VirtualHost
string VirtualHostMacAddress 00-AC-5E-74-70-C4
declare VirtualRouter
bool NatEnabled true
uint NatMtu 1500
uint NatTcpTimeout 1800
uint NatUdpTimeout 60
declare CertList
declare CrlList
declare GroupList
declare IPAccessControlList
declare UserList
declare Traffic
declare RecvTraffic
uint64 BroadcastBytes 0
uint64 BroadcastCount 0
uint64 UnicastBytes 0
uint64 UnicastCount 0
declare SendTraffic
declare test
uint64 CreatedTime 1394142424414
byte HashedPassword ******/jjBuTYEXc7puiX2HzI=
uint64 LastCommTime 1395609798681
uint64 LastLoginTime 1394151829404
uint NumLogin 3
bool Online true
byte SecurePassword gb+**************=
uint Type 0
declare AccessList
declare AdminOption
uint deny_bridge 0
uint deny_qos 0
uint deny_routing 0
uint max_groups 0
uint max_sessions 0
uint max_users 0
uint no_cascade 0
uint no_offline 0
uint no_online 0
uint no_securenat 0
declare CascadeList
declare LogSetting
declare Message
declare Option
uint MaxSession 0
bool NoEnum false
declare SecureNAT
bool Disabled false
bool SaveLog true
string DhcpDnsServerAddress 10.10.10.1
string DhcpDnsServerAddress2 8.8.8.8
string DhcpGatewayAddress 10.10.10.1
string DhcpLeaseIPEnd 10.101.10.200
string DhcpLeaseIPStart 10.10.10.10
declare VirtualHost
string VirtualHostIp 10.10.10.1
string VirtualHostMacAddress 00-AC-08-6B-D5-F9
uint NatMtu 1500
declare CertList
declare CrlList
declare GroupList
declare UserList
declare test
byte AuthNtLmSecureHash ***************==
byte AuthPassword ZadK3/*******************=
uint AuthType 1
uint64 CreatedTime 1394142471049
uint64 ExpireTime 0
string Note testing$20l2tp
uint NumLogin 3
string RealName test$20test
uint64 UpdatedTime 1394142997250
declare Traffic
declare RecvTraffic
uint64 BroadcastBytes 34040
uint64 BroadcastCount 505
uint64 UnicastBytes 9455246
uint64 UnicastCount 17707
declare SendTraffic
uint64 BroadcastBytes 259708
uint64 BroadcastCount 2036
uint64 UnicastBytes 1335618
uint64 UnicastCount 12510
declare Traffic
declare RecvTraffic
uint64 BroadcastBytes 35379428
uint64 BroadcastCount 577836
uint64 UnicastBytes 22851470
uint64 UnicastCount 317509
declare SendTraffic
uint64 BroadcastBytes 293748
uint64 BroadcastCount 2541
uint64 UnicastBytes 22831300
uint64 UnicastCount 317421
declare VPN
uint64 CreatedTime 1393596791656
byte HashedPassword *********************=
uint64 LastCommTime 1395609801657
uint64 LastLoginTime 1395580422789
uint NumLogin 270
bool Online true
byte SecurePassword is4FLK/***************=
uint Type 0
declare AccessList
declare AdminOption
uint deny_bridge 0
uint deny_qos 0
uint deny_routing 0
uint max_groups 0
uint max_sessions 0
uint max_users 0
uint no_cascade 0
uint no_offline 0
uint no_online 0
uint no_securenat 0
declare CascadeList
declare LogSetting
declare Message
declare Option
uint MaxSession 0
bool NoEnum false
declare SecureNAT
bool Disabled false
bool SaveLog true
string DhcpDnsServerAddress 10.10.8.1
string DhcpGatewayAddress 10.10.8.1
string DhcpLeaseIPEnd 10.10.8.200
string DhcpLeaseIPStart 10.10.8.10
declare VirtualHost
string VirtualHostIp 10.10.8.1
string VirtualHostMacAddress 00-AC-EF-89-03-7D
uint NatMtu 1500
declare CertList
declare CrlList
declare GroupList
declare Traffic
declare RecvTraffic
uint64 BroadcastBytes 93414710
uint64 BroadcastCount 1206429
uint64 UnicastBytes 11030291860
uint64 UnicastCount 23487832
declare SendTraffic
uint64 BroadcastBytes 89258890
uint64 BroadcastCount 913558
uint64 UnicastBytes 11023983957
uint64 UnicastCount 23574832
Hsec
Post by Hsec » Tue Mar 25, 2014 8:01 pm
By the way, I can connect to the server (l2tp) using softether client and it works perfect. the problem is that even I can connect to the server using android built-in l2tp client, there are no connection to internet.
Post by thisjun » Wed Mar 26, 2014 6:17 pm
Did your android succeed getting IP or DNS or default gateway from DHCP?
And is there any message in android?
Hsec
Post by Hsec » Fri Mar 28, 2014 8:07 pm
Yes, based on the logs, it get both IP and DNS and default gateway from dhcp. I also ran tcpdump on server to see if server receives client packets, and I clearly can see the client requests. But for an unknown reason, the server cannot communicate properly with connected client.
I would appreciate it if anyone could help.
geraldgreen
Post by geraldgreen » Tue Apr 01, 2014 5:44 am
Please fix this issue for mobile phones, I can't connect as well (L2TP/IPSEC with the correct ports open) but everything else works on other platforms. Thanks!
szafar
Post by szafar » Tue Apr 01, 2014 6:47 pm
I had been scratching my head for the last three days on this issue. I could get a dhcp address and was able to ping the router from Android but nothing else worked. Could not ping the assigned address, traceroute showed !H. I did not have any other client type except Android so could not test any other platform. I am running my SoftEther server on a Raspberry Pi and was thinking there is something wrong with my configuration or limitation of the hardware.
mesa57
Post by mesa57 » Tue Apr 01, 2014 7:02 pm
Works fine here on android 4.x
szafar
Post by szafar » Tue Apr 01, 2014 10:58 pm
Are you using two NICs?
Here is log from my server ....
2014-04-01 18:56:03.423 [HUB "Home"] Session "SID-LOCALBRIDGE-1": The DHCP server of host "F8-E4-FB-82-69-11" (192.168.1.1) on this session allocated, for host "SID-NOTE-[L2TP]-5" on another session "CA-81-E5-6D-F3-D4", the new IP address 192.168.1.2.
2014-04-01 18:56:03.434 L2TP PPP Session [208.54.35.237:1701]: An IP address is assigned. IP Address of Client: 192.168.1.2, Subnet Mask: 255.255.255.0, Default Gateway: 192.168.1.1, Domain Name: "", DNS Server 1: 192.168.1.1, DNS Server 2: 0.0.0.0, WINS Server 1: 0.0.0.0, WINS Server 2: 0.0.0.0, IP Address of DHCP Server: 192.168.1.1, Lease Lifetime: 86400 seconds
2014-04-01 18:56:03.434 L2TP PPP Session [208.54.35.237:1701]: The IP address and other network information parameters are set successfully. IP Address of Client: 192.168.1.2, Subnet Mask: 255.255.255.0, Default Gateway: 192.168.1.1, DNS Server 1: 192.168.1.1, DNS Server 2: 0.0.0.0, WINS Server 1: 0.0.0.0, WINS Server 2: 0.0.0.0
^C
#:/opt/vpnserver/server_log# ping 192.168.1.2
PING 192.168.1.2 (192.168.1.2) 56(84) bytes of data.
^C
--- 192.168.1.2 ping statistics ---
7 packets transmitted, 0 received, 100% packet loss, time 6004ms
szafar
Post by szafar » Wed Apr 02, 2014 2:02 am
Just added a USB ethernet adapter. Made this adapter bridge device. Same result! Must be doing something fundamentally wrong here. Do see traffic .... Main_Router is 192.168.1.1 ...
tcpdump -vv -i eth1 host 192.168.1.2
tcpdump: WARNING: eth1: no IPv4 address assigned
tcpdump: listening on eth1, link-type EN10MB (Ethernet), capture size 65535 bytes
21:47:32.015521 IP (tos 0x10, ttl 16, id 0, offset 0, flags [none], proto UDP (17), length 328)
Main_Router.bootps > 192.168.1.2.bootpc: [udp sum ok] BOOTP/DHCP, Reply, length 300, xid 0x9594b7ec, Flags [none] (0x0000)
Your-IP 192.168.1.2
Server-IP Main_Router
Client-Ethernet-Address ca:81:e5:6d:f3:d4 (oui Unknown)
Vendor-rfc1048 Extensions
Magic Cookie 0x63825363
DHCP-Message Option 53, length 1: Offer
Server-ID Option 54, length 4: Main_Router
Lease-Time Option 51, length 4: 86400
Subnet-Mask Option 1, length 4: 255.255.255.0
Default-Gateway Option 3, length 4: Main_Router
Domain-Name-Server Option 6, length 4: Main_Router
21:47:32.321713 IP (tos 0x10, ttl 16, id 0, offset 0, flags [none], proto UDP (17), length 328)
Your-IP anonymous
DHCP-Message Option 53, length 1: ACK
21:47:32.705919 ARP, Ethernet (len 6), IPv4 (len 4), Request who-has 192.168.1.2 tell Main_Router, length 46
21:47:34.439183 ARP, Ethernet (len 6), IPv4 (len 4), Reply 192.168.1.2 is-at ca:81:e5:6d:f3:d4 (oui Unknown), length 28
21:47:52.330986 IP (tos 0x0, ttl 64, id 0, offset 0, flags [DF], proto ICMP (1), length 84)
192.168.1.2 > 192.168.1.80: ICMP echo request, id 27, seq 1, length 64
21:47:53.422288 IP (tos 0x0, ttl 64, id 0, offset 0, flags [DF], proto ICMP (1), length 84)
192.168.1.2 > 192.168.1.80: ICMP echo request, id 27, seq 2, length 64
Don't see reply from 192.168.1.80 going back ... If ping 192.168.1.2 from 192.168.1.80
I see traffic going from .80 to .2 but no reply!
Please help.
geraldgreen
Post by geraldgreen » Sat Apr 05, 2014 1:33 am
Still can't resolve this issue.
