Unable to Remote Desktop (RDP) to VPN Host
terryfied
Post by terryfied » Fri Jan 31, 2014 6:10 am
I have six machines on my home network and I have SoftEther Server running on one of them so that I can VPN into my home network from work and log into any of my home machines using Remote Desktop (RDP).
This works great for all machines except the machine SoftEther Server is running on. I can RDP into one of machines and then RDP from that machine to the VPN host, but cannot RDP directly into the VPN host machine. I have tried using the hostname, FQDN and IP but it will not connect from outside. Any help? Thanks.
mesa57
Re: Unable to Remote Desktop (RDP) to VPN Host
Post by mesa57 » Fri Jan 31, 2014 7:22 am
Can you ping the machine ? Did you not use SecureNat and create a local bridge to you're hub ?
terryfied
Post by terryfied » Fri Jan 31, 2014 9:42 am
No, I did not use SecureNAT as I had a hard time understanding the setup and purpose of it. I'll look into setting that up. Thank you for the info.
terryfied
Post by terryfied » Sat Feb 01, 2014 4:29 am
Well, it's really strange. I can RD into the VPN host machine using my laptop and a VZW hotspot connection, but I can't using my work PC. I don't think it's got anything to do with network connections because I can hit every other machine on my network when VPN is connected. Do I need to use SecureNAT?
Also...I cannot ping the machine using the hostname, IP or FQDN. However, I can perform an nslookup on the hostname and it finds the proper IP and vice versa.
dav
Post by dav » Thu Jul 24, 2014 2:16 pm
Same problem here, unless I cannot RDP to any machine in the LAN I'm connecting to. Any help?
inten
Contact:
Post by inten » Thu Jul 24, 2014 2:35 pm
http://www.vpnusers.com/viewtopic.php?f=7&t=2790
dav
Post by dav » Thu Jul 24, 2014 3:08 pm
Ok then...
1. Operating system name and the type of CPU-bits
SO: Windows Server 2008 Standard 64bits
CPU: Intel i3-2100
2. The result of "ifconfig –a" (UNIX) or "ipconfig /all" (Windows)
C:\Users\Administrator>ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : BAS
Primary Dns Suffix . . . . . . . :
Ethernet adapter Local Area Connection:
Description . . . . . . . . . . . : Intel(R) 82574L Gigabit Network Connectio
n
Physical Address. . . . . . . . . : 34-40-B5-87-E8-C5
Link-local IPv6 Address . . . . . : fe80::d88e:80e:b3d4:a56a%10(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.30.29(Preferred)
Default Gateway . . . . . . . . . : 192.168.30.1
DHCPv6 IAID . . . . . . . . . . . : 238305461
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-18-0F-1E-95-34-40-B5-87-E8-C5
DNS Servers . . . . . . . . . . . : 8.8.8.8
8.8.4.4
Ethernet adapter VirtualBox Host-Only Network:
Description . . . . . . . . . . . : VirtualBox Host-Only Ethernet Adapter
Physical Address. . . . . . . . . : 08-00-27-00-F8-CE
Link-local IPv6 Address . . . . . : fe80::fc67:939c:1b1e:3ff6%17(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.56.1(Preferred)
DHCPv6 IAID . . . . . . . . . . . : 218628135
DNS Servers . . . . . . . . . . . : fec0:0:0:ffff::1%1
fec0:0:0:ffff::2%1
fec0:0:0:ffff::3%1
Tunnel adapter Local Area Connection* 8:
Description . . . . . . . . . . . : isatap.{98E9E995-60D0-47F1-83E4-C049EFFF5
B57}
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
Tunnel adapter Local Area Connection* 12:
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
Physical Address. . . . . . . . . : 02-00-54-55-4E-01
Tunnel adapter Local Area Connection* 15:
Description . . . . . . . . . . . : isatap.{A58496DA-64F1-413A-A9FB-A21F2290A
865}
3. The result of "uname –a" (UNIX) or "systeminfo" (Windows)
Host Name: BAS
OS Name: Microsoft® Windows Server® 2008 Standard
OS Version: 6.0.6002 Service Pack 2 Build 6002
OS Manufacturer: Microsoft Corporation
OS Configuration: Standalone Server
OS Build Type: Multiprocessor Free
Registered Owner: Windows User
Registered Organization:
Product ID: 55041-291-7479071-76546
Original Install Date: 16/10/2012, 10:52:28
System Boot Time: 22/07/2014, 20:07:42
System Manufacturer: IBM
System Model: IBM System X3100 M4 -[2582AC1]-
System Type: x64-based PC
Processor(s): 1 Processor(s) Installed.
[01]: Intel64 Family 6 Model 42 Stepping 7 GenuineIn
el ~1600 Mhz
BIOS Version: IBM Corp. -[JQE150AUS-1.02]-, 27/06/2012
Windows Directory: C:\Windows
System Directory: C:\Windows\system32
Boot Device: \Device\HarddiskVolume1
System Locale: es-ar;Spanish (Argentina)
Input Locale: N/A
Time Zone: (GMT-03:00) Buenos Aires
Total Physical Memory: 4.083 MB
Available Physical Memory: 1.511 MB
Page File: Max Size: 8.404 MB
Page File: Available: 4.932 MB
Page File: In Use: 3.472 MB
Page File Location(s): C:\pagefile.sys
Domain: TRIMIX
Logon Server: \\BAS
Hotfix(s): 7 Hotfix(s) Installed.
[01]: {47740627-D81D-4A45-A215-03B075A18EC7}
[02]: {A8E86480-A9C1-4414-8AA2-B05A485C82F0}
[03]: {4AFF0FEB-1A23-48FE-9FBA-BEC37EECE0EE}
[04]: {511481D6-EE5F-4884-AF68-43E0183F8FB9}
[05]: {65AFCB03-3111-47E2-B1ED-198D6B0BC96E}
[06]: KB955430
[07]: KB968930
Network Card(s): 2 NIC(s) Installed.
[01]: Intel(R) 82574L Gigabit Network Connection
Connection Name: Local Area Connection
DHCP Enabled: No
IP address(es)
[01]: 192.168.30.29
[02]: fe80::d88e:80e:b3d4:a56a
[02]: VirtualBox Host-Only Ethernet Adapter
Connection Name: VirtualBox Host-Only Network
DHCP Enabled: No
IP address(es)
[01]: 192.168.56.1
[02]: fe80::fc67:939c:1b1e:3ff6
4. The build number of SoftEther VPN
v4.09.9451
5. Which SoftEther VPN component are you using?
SoftEther VPN Server
6. Whether or not there is a NAT or Firewall between your VPN server and the Internet.
(If there is a NAT or Firewall, you should open a TCP port for the VPN listener.)
Just a loadbalancing router doing NAT with 4 WANs from differents ISPs. SoftEther is listening on port 5555, which is forwarded by the router to the PC running the VPN Server (192.168.30.29).
7. Are you using SecureNAT?
No.
8. Your current vpn_server.config or vpn_bridge.config file should be attached on the post.
Already attached.
Thanks in advance.
Post by thisjun » Tue Aug 12, 2014 4:51 am
Do you use hardware offloading on NIC?
Please try to turn off hardware offloading and reboot the machine.
Please check localbridge manual. http://www.softether.org/4-docs/1-manua ... in_Windows
wannabess99
Post by wannabess99 » Tue Apr 02, 2019 9:48 pm
Hello
The problem for RDP and VNC and others application, that you cant use the same netword card for VPN server and remote desktop the same machine.
Best regards
Moonrunner
Post by Moonrunner » Wed Apr 17, 2019 12:16 pm
Also cant use the same netword card for VPN server and remote desktop at the same machine!
