Integrating Google Authenticator with softether vpn
satyanvesh
Post by satyanvesh » Fri Jan 31, 2014 12:03 pm
Hi
Can we integrate google authenticator with the softether vpn?? If yes please help me out to configure it or high level steps for configuring.
Regards
Satyanvesh
inten
Contact:
Re: Integrating Google Authenticator with softether vpn
Post by inten » Sun Feb 02, 2014 11:34 am
Hi.
You can do it for sure! Submit your patch here https://github.com/SoftEtherVPN/SoftEtherVPN
When you don't like the answer, change the question.
Cheers,
Team.
VPNHPanel.com
This account is not associated to SoftEther project.
satyanvesh
Post by satyanvesh » Mon Feb 03, 2014 3:40 am
Thanks for the quick response
Apologies for the delay. Can you please tell what patch you were talking about.
Thanks
inten
Contact:
Post by inten » Mon Feb 03, 2014 5:32 am
You need to write it, there is no built-in feature.
satyanvesh
Post by satyanvesh » Mon Feb 03, 2014 6:36 am
Is there any way to integrate with softether client vpn manager with google authenticator without writing any code.
Thanks
inten
Contact:
Post by inten » Mon Feb 03, 2014 6:51 am
Obviously no.
satyanvesh
Post by satyanvesh » Mon Feb 03, 2014 7:04 am
Do I need to write an os level program to integrate google authenticator with softether vpn. If yes please help me out how to acheive this.
Thanks
inten
Contact:
Post by inten » Mon Feb 03, 2014 7:14 am
anilr2u
Post by anilr2u » Sun Sep 29, 2019 1:00 pm
Do we have a solution for Softether VPN on Windows to integrate with google authenticator TOTP?, if yes then give the code changes to be done or the patch to be integrated to it on windows.
fenice
Post by fenice » Sun Sep 29, 2019 1:22 pm
This thread is over five years old, do not add your post to old threads in the future. If you want to find a specific feature or file an RFE then go to Github and search there and if you don't find anything then file an RFE.
Regards
Bill
