I can only connect using port 443 in openvpn but whenever I try to connect to port 443 in softether "error code 2: protocol error occured" shows.
Can anyone help me?
						Error code 2: Protocol error occured.
				inten
Re: Error code 2: Protocol error occured.
Did you configure OpenVPN to accept connections on the 443 port?
				illhangon
No. I simply download port 443 openvpn config files from vpngate and connect.
				inten
You need to configure SE OpenVPN setting to accept connections on 443 port.
				illhangon
Can you please tell me how to do that?
