HI,
anyone can guide me how to disable the encryption option of storing the user's password in vpn_server_config file? i need the password to be stored in plain text.
Also how to include the user_list from from external file in the vpn_server_config?
regards,
Mike
Disabling User password encryption
Re: Disabling User password encryption
> in plain text.
Why (the hell) do you need that? And I don't belive that is possible without changing some sources....
> vpn_server_config?
Wait for the RADIUS-Implementation and set one up or just by writing some scripts doing that for you. Take a look in the manual. 6.2.3 and 6.2.4 (https://www.softether.org/4-docs/1-manu ... _of_vpncmd)
> in plain text.
> vpn_server_config?
Hi qupfer
well i need it because i need to read the users from my users list which are available in other hash file
Any idea which script needs to be edited ?
SoftEther has its private management tool to control vpnserver or vpnbridge.
It is pretty hard to be controlled in Embedded System.
Here is a method to create passwords for user list, it is cli command in linux and openssle, the command will create a base64 password for user_list.
admin is a password and the key is come from checked source codes.
echo -ne "admin" | openssl rc4 -K "456E637279707450617373776F726432" -e -a -nopad -nosalt
Thank you arprip
But my point is to avoid using the users list defined in the vpn_server_config file.
i need to define in the vpn_server_config file a link to another file which contains all users list and each user password should be stored in plain text.
is that possible?
Mike
is that possible?
Mike
SoftEther can't disable the encryption option of storing the user's password in vpn_server_config file.
If you want to manage users by another file, it's better to make script or program using vpncmd (http://www.softether.org/4-docs/1-manua ... _of_vpncmd).
