Hello sir,
Vpn servers runs at -20 how can i change it during start please
How to change priority vpnserver
Re: How to change priority vpnserver
You can modify the values on the UnixSetHighPriority() function.
Hello I have to do renice .I'm looking out how to start softether at Priority 0
renice -n x -p pidofvpnserver
x can be -20 to 19, but only root can use negative number
So here you want
renice -n 0 -p pidofvpnserver
or
nice -n 0 vpnserver
So here you want
or
nice -n 0 vpnserver
nice -n 0 vpnserver
SoftEther VPN Server Service Program
vpnserver Command Usage:
vpnserver start - Start SoftEther VPN Server Service.
vpnserver stop - Stop SoftEther VPN Server Service if the service is already started.
this command don't work sir.
Change to use renice
1. run vpnserver start.
2. Check pid number in hidden .pidxxxx file
3. run renice -n 0 -p pidnumber
it should be work.
it should be work.
sir I'm doing this way .But i want it without doing renice and have least low priority like Http,mysql and other .Can you help me how
Why you think it doesn't work? The part:
is output of SoftEther. So you just need to follow these instrutructions.
'sudo nice -n 0 vpnserver start'
