How to know vpnserver pid ?
arprip
Post by arprip » Wed Mar 12, 2014 10:22 am
Hi, All:
I know that when vpnserver is running, there is a pid file will be created.
but it seems that it will be random appended some number in filename.
based no change source codes, Could it always use this same filename
for example the filename for pid is vpnserver_pid
it will easy to use script to stop / restart it again.
Any good suggestion about this ?
