add automatically routing information
mstenz
Post by mstenz » Wed Mar 19, 2014 9:41 pm
iam Using both VPN Server and VPN bridges to crossconnect (via L3 Switch) different Office networks. (for example 10.10.10.0 for users network, 10.10.11.0 for printers network and so on)
Additionall I enabled normal clients (windows client vpn software) to "dial" in to one of my virtual hubs.
After that was successfull a connection from the client to all devices in the same network (10.10.10.0) is possible.
I have configured no additional default gateway to the client. This means 0.0.0.0 gets routed via the default network card from the clients device.
How iam able to let automatically add all the other routes from the L3 switch added to the clients routing table?
help much appreciated.
thx.
rgds.
Michael
dnobori
Re: add automatically routing information
Post by dnobori » Thu Mar 20, 2014 3:28 am
Use the split-tunneling function, added on the Build 9430.
You can configure the routing table to push to client, on the setting screen of the SecureNAT DHCP Server.
http://www.softether.org/5-download/history
mstenz
Post by mstenz » Thu Mar 20, 2014 8:09 am
thx, this is really great. I will test that out directly.
parkycai
Post by parkycai » Thu Mar 20, 2014 8:29 am
THX for the split-tunneling function.
been waiting for this function for 10 years, no kidding.
dnobori
Post by dnobori » Thu Mar 20, 2014 2:47 pm
Sounds great. Try it.
parkycai
Post by parkycai » Thu Mar 20, 2014 4:50 pm
I get a message which says "This feature is not supported. It hasn't been implemented yet on the open-source version of SoftEther VPN" after I click OK in the "Edit the static routing table to push" window. The client does not receive the classless routes either.
I checked the VPN Server Information and found that the value of "Static Routing Table Pushing Function" is No, and the value of "Static Routing Table Pushing Function(Configurable)" is Yes.
I also cleared the Default Gateway Address in the SecureNAT Configuration and added a static route entry "192.168.10.0/255.255.255.0/192.168.102.1" in the push configuration window.
I'm using build 9432, running on Win2012 R2.
mstenz
Post by mstenz » Thu Mar 20, 2014 5:21 pm
interesting @ parkycai
I have tested also on server 2012R2 and for me it works very well without error messages.
parkycai
Post by parkycai » Sun Apr 06, 2014 5:39 am
I installed the latest v4.06b9435 but still no luck. Here're some screen shots
[attachment=1]serverInfo.jpg[/attachment]
[attachment=0]classlessRoutes.jpg[/attachment]
I'm using Win 2012. Is there anyone having same issue with me?
parkycai
Post by parkycai » Sun Apr 06, 2014 5:41 am
> shots
> I'm using Win 2012 R2. Is there anyone having same issue with me?
BTW, how to activate "Lightweight Kernel-mode Ethernet Driver"?
***********Edit**************
Sorry, the OS is Win2012, not R2. I suppose it's not supported on 2012. On the other server running 2012 R2, it's working.
But the static-routing push function is still not working on 2012 R2.
inten
Contact:
Post by inten » Sun Apr 06, 2014 5:51 am
SoftEther VPN 4.05 Build 9422 (Beta) (February 17, 2014)
Added the NSDI 6.x Lightweight Helper Kernel-mode Module for the local-bridge function. This kernel-mode driver runs only on Windows 8.1 / Windows Server 2012 R2 or later.
When you don't like the answer, change the question.
Cheers,
Team.
VPNHPanel.com
This account is not associated to SoftEther project.
parkycai
Post by parkycai » Sun Apr 06, 2014 5:53 am
> or later.
thanks inten. I realized it's my mistake.
parkycai
Post by parkycai » Sun Apr 06, 2014 6:07 am
here's my server config file. hope it helps to locate the problem
samenlia
Post by samenlia » Wed Apr 09, 2014 12:23 pm
> shots
你在天朝吧。
enterprises functions are currently disabled by default in Region of china。
while it is opensource, you can modify the code and rebuild it。
just look at src\Cedar\server.c function SiIsEnterpriseFunctionsRestrictedOnOpenSource()
Please see this page http://www.softether.org/5-download/history
"On VPN Servers in People's Republic of China, the above five functions are currently disabled by default, under the orders from Beijing. Although Chinese users can enable these functions manually, Enterprise users in People's Republic of China are recommended to use these enterprise functions with PacketiX VPN Server 4.0 Chinese Edition."
parkycai
Post by parkycai » Fri Jul 15, 2022 8:56 am
> shots
你在天朝吧。
感谢,8年之后终于编了一个版本出来用了 囧
