I was wondering if anyone had any success using the OpenVPN client on the iPhone? I am using the SofteEther VPN Server 4.06 Build 9432. I just curious to see what I can do with the new features.
Thanks,
Bobby
						iPhone OpenVPN Client
				qupfer
Re: iPhone OpenVPN Client
Yes, I'm using it and works great.
				brlathanjr
I was trying to configure it with no success. Could you please advise me how to configure it? Thanks!
				qupfer
I will try, if you post some mor information about your setting, like which OS you are using. Is SecureNAT enabled or not, using SoftEthers DynDNS Service or a other one, have you normal pc clients and if yes, did they working, have you a error message of openvpn and all other more or less important informatios.
