why is it needed to stop the virtual L3 switch when changing the settings?
Doing that will completely interrupt the traffic. Isnt there a possibility to add or delete switch configurations while the switch is up?
I plan to have a lot of different L3 networks/hubs (will be 300-500) while adding the configuration daily. And with the current possibility there will be many interruption of the service.
Any suggestions?
rgds.
Michael
						Layer 3 Switch start and stop
				dnobori
Re: Layer 3 Switch start and stop
The current version of SoftEther VPN Server doesn't support the L3SW on-the-running configuration. Your contribution to the source code is much appriciated! https://github.com/SoftEtherVPN/SoftEtherVPN/
				mstenz
even If i whould I cannot contribute, because of missing deep knowledge in developer skills :(
But can you please give me a hint what technical thing currently prevents the possibility to change data "live"? So maybe if I understand whats the reason why its developed like that, I also will understand how much work it will need to change something to it and can see if I am able to fund it.
rgds.
Michael
rgds.
Michael
