Replace HUBs by SWITCHes (Feature request)
kbi
Post by kbi » Fri Mar 28, 2014 4:29 am
I am using SoftEther Client Version 4.04 on Ubuntu 10.04.4 LTS (x86/32 Bit). It works fine. Thank you, dnobori, for this great software!
After connecting to vg1868122484.opengw.net via SSL-VPN and starting tcpdump on my virtual interface I see a lot of traffic not related to my computer, but to approx. 100 foreign stations. In a quick look I identified:
- ARP requests and answers
- DHCP request and leases
- TCP/IP packets TO stations on the HUB
- and more (but no TCP/IP FROM stations on the HUB)
This traffic is useless. It is wasting bandwidth and violates privacy. May be it is a security risk.
To improve your software I suggest: Replace the soft HUBs in your server by soft SWITCHes.
inten
Contact:
Re: Replace HUBs by SWITCHes (Feature request)
Post by inten » Sat Mar 29, 2014 1:39 am
just wondering what SWITCH you are talking about, L2/L3 or something else?
> soft SWITCHes.
dnobori
Post by dnobori » Sat Mar 29, 2014 2:30 am
A Virtual Hub is already a L2 Ethernet switch.
kbi
Post by kbi » Sun Mar 30, 2014 10:52 am
To my understanding: No!
Both hardware HUBs and SWITCHes operate on L2, but difference is:
- A hardware HUB on a network sends traffic from a port to all other of its ports. So does your software according my observation. That is bad.
- A hardware SWITCH is a HUB that filters packets by ethernet address and sends received unicast packets from a port only to that port which has the correct destination ethernet address attached. So your software should do, I suggest.
USADriver60
Post by USADriver60 » Mon Mar 31, 2014 2:06 pm
kbi,
Did you have "Privacy Filter Mode" enabled on your User's - Security Policy when you ran your test?.
Regards, Philip
