hi,
is there an option to automatically stop applications (connecting to internet) if the VPN connection stops or crashes please?
my problem is for utorrent for example.
thank you
						automatically stop applications if the VPN connection stops
				franckinou
Re: automatically stop applications if the VPN connection st
Could  you give me more information of the problems?
				franckinou
hello,
if I use applications that connect to the internet and go through the VPN, I want the VPN stops these applications if the VPN connection is stopped.
I know the VPN retry a connection if it is lost. but the application continues to connect to the Internet no longer passing through the VPN but directly by my Internet Service Provider if the VPN connection is not accomplished ..
I do not want third party software but an option SoftEther. the same thing as this software:
http://forum.pcinpact.com/topic/156311- ... -des-vpns/
thank you for your help
				inten
SE doesn't provide such function (and it is not intended to do), but you can use OpenVPN client to connect to the SE server, there is an option called "Seamless Tunnel" that will help you.
Cheers.
						Cheers.
