hi i want emulate the services of openvpn my basic config is request is UDP port 53
I set the tab that belongs in the windows manager softether
i put the generated .ovpn in my android, and dont conect nothing
my principal dude is all listeners ports are TCP, 443. But i need listener port 53 udp
that's probably the bug that I can not connect to my server
any recommendation ??? thx for you response
PD: all ports open in the machine, VPN over DNS is active and secureNAT is enabled
[DUDE] Problem protocol Openvpn
Re: [DUDE] Problem protocol Openvpn
If you just enabled openvpn feature to listen on your desired port then it should listen for both udp and tcp automaticaly. Vpn over dns got nothing to do with openvpn vpn feature ao better disabled it.
thx friendo now conect, but dont have traffic of internet, dont have packets in/out
any idea sir???
any idea sir???
After enabling secure nat dont forget to enable virtual dhcp.
