Client tries to connect to strange host using SSL
				Eeared
I've been trying the server and client and it works as intended, but one thing has come up.
When I log on to my client machine using my domain details, I get a warning from our firewall stating that the Soft Ether VPN Client is trying to communicate over SSL to host ddns-register-1.sehosts.com
I've tried googling as to what this site is, or what it might be used for, but I'm having no luck. Could you please enlighten me as to why the client tries to talk to this host without me doing anything?
Thanks.
Thanks.
Re: Client tries to connect to strange host using SSL
Is it correct host name or typo?
Could you re-confirm the host name?
				Eeared
Please see the screenshot.
ddns-register-1.sehosts.com is using for DDNS.
However latest version not use the host.
Please use latest version.
				Eeared
After updating I'm sorry to say this issue still remains.
Please advise.
Please advise.
Could you tell me about version of softether?
				Eeared
Using version softether-vpnclient-v4.06-9437-beta-2014.04.09-windows-x86_x64-intel
				Eeared
Sorry to be that annoying person, but, this is still occurring.
				dnobori
I suppose that Dynamic DNS (DDNS) function is enabled on your SoftEther VPN Server. In order to register itself to the "softether.net" Dynamic DNS (DDNS) domain, the VPN Server communicates with the central DDNS server in regular peroid. If you do not need DDNS function, disable the function on the configuration file of VPN Server.
				vpnusers
dnobori wrote: ↑Wed Jun 04, 2014 6:22 pmI suppose that Dynamic DNS (DDNS) function is enabled on your SoftEther VPN Server. In order to register itself to the "softether.net" Dynamic DNS (DDNS) domain, the VPN Server communicates with the central DDNS server in regular peroid. If you do not need DDNS function, disable the function on the configuration file of VPN Server.
How do you disable the DDNS in the config file?
構成ファイルでDDNSを無効にするにはどうすればよいですか?
上
Kōsei fairu de DDNS o mukōnisuru ni wa dōsureba yoidesu ka? Ue
