Here are the symptoms:
1,Individual certificate authentication doesn't work. Settings can not be saved. Even when I edit the config file manually, it will be replaced with password authentication.
2,Clients can't receive ip addresses form virtual dhcp as well as pushed routes.
Everything works fine on windows, so I don't think it has anything to do with the server.
Here are my clients' environments.
1. Operating system name and the type of CPU-bits
arm linux 3.4 and openwrt AA 12.9
2. The result of "ifconfig –a" (UNIX) or "ipconfig /all" (Windows)
eth0      Link encap:Ethernet  HWaddr 00:24:8c:02:75:70
          inet addr:192.168.100.250  Bcast:192.168.100.255  Mask:255.255.255.0
          inet6 addr: fe80::224:8cff:fe02:7570/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:1807256 errors:0 dropped:385 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:531355795 (506.7 MiB)  TX bytes:644812156 (614.9 MiB)
tunl0     Link encap:IPIP Tunnel  HWaddr
          NOARP  MTU:1480  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          collisions:0 txqueuelen:0
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
vpn_net0  Link encap:Ethernet  HWaddr 00:ac:5e:94:b9:53
          inet addr:192.168.10.2  Bcast:192.168.10.255  Mask:255.255.255.0
          inet6 addr: fe80::2ac:5eff:fe94:b953/64 Scope:Link
          RX packets:3918 errors:0 dropped:0 overruns:0 frame:0
          TX packets:3639 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:500
          RX bytes:244986 (239.2 KiB)  TX bytes:262262 (256.1 KiB)
I added that ip to vpn_net0 manually.
4. The build number of SoftEther VPN
   4.06-9437-beta-2014.04.09 for arm linux and 4.06-9435 for openwrt
6. Whether or not there is a NAT or Firewall between your VPN server and the Internet.
   no
7. Are you using SecureNAT?
   Yes
						Problems with securenat and authentication
Re: Problems with securenat and authentication
Do you use SoftEther in China?
If you use in China, Individual certificate authentication is currently disabled by default.
Please read here http://www.softether.org/5-download/history
On VPN Servers in People's Republic of China, the above five functions are currently disabled by default, under the orders from Beijing. Although Chinese users can enable these functions manually, Enterprise users in People's Republic of China are recommended to use these enterprise functions with PacketiX VPN Server 4.0 Chinese Edition.
				bob0102
Hi thisjun,
Thanks for the reminder. I modified the source code, and CA is working now, but still no luck with DHCP. As I mentioned before, windows version worked fine. Is there something else I missed?
Which client do you use in Linux?
				bob0102
They both had the same result.
