Dear guru users,
I strictly followed the following steps to install vpnserver on fedora system. I installed in root mode, all listener ports are open and vpn server checks pass. I believe vpnserver is running because I can use vpncmd on the server to enter the management console. However, if I use server manager on a windows machine(remote), I always get "protocol error". Both sides are completely open, no firewall of any kind exists. Anyone encountered similar issues or what could be the issue?
http://www.softether.org/4-docs/1-manua ... igurations
Thank you so much
						Cannot connect to server via server manager
				darkdancer
Re: Cannot connect to server via server manager
Did you get the message by using the manager in same LAN with VPN server?
