Calling the experts among you!
stanislav
Post by stanislav » Sun May 18, 2014 1:50 am
Hello ladies and gentleman,
I need your expert advice, so lets get to the basics ...
Let's assume that I have 4 static IPs obtained from my ISP.
I need to be able to assign each static ip to a separate user account in windows 7
What would be the best way to go about it?
Should I just get an Ethernet card with 4 ports and then assign each static IP to a separate user account in windows 7? Is it even possible?
What about Wi-Fi? Is it possible to assign multiple static IPs via WiFi, each to a separate user account in windows 7?
Thank you!
inten
Contact:
Re: Calling the experts among you!
Post by inten » Sun May 18, 2014 3:20 am
Hi.
Very interesting how your question relates to SoftEther?
stanislav
Post by stanislav » Sun May 18, 2014 4:03 am
inten wrote:
> Hi.
I am hoping that maybe someone is going to give me solution using SoftEther to set up virtual nic. Is it possible ?
inten
Contact:
Post by inten » Sun May 18, 2014 3:56 pm
Looks like you have missed the forum or something else had happened to you. SoftEther is intended to build a Virtual Private Network (VPN).
theodisbutler
Post by theodisbutler » Tue May 27, 2014 1:42 am
I know this is possible with a domain controller and active directory setup.
