I want to setup a LAN-to-LAN all on Amazone EC2.
[I previously setup a Remote Access to VPN Server - in which case I did not build a bridge but used Secure NAT).
Having no luck with the LAN-TO-LAN.
Do I need to setup Bridges?
DO I need to setup Secure NAT/DHCP
Other than from the server on each side, do users need to also use a client to login?
Thanks in advance.
						LAN-TO-LAN Amazon 2 VPC
				griznet
LAN-to-LAN on Amazon EC2 between two VPCs
Reworded....
I want to setup a LAN-to-LAN on Amazon EC2 between two VPCs
[I previously setup a Remote Access to VPN Server between two VPCs - in which case I did not build a bridge but used Secure NAT/DHCP).
DO I need to setup Secure NAT/DHCP? On both sides?
Other than from the server on each side, do users need to also use a client to login, or does the Cascade connection create the connection for everyone?
Thanks in advance.
Thanks in advance.
				inten
Re: LAN-TO-LAN Amazon 2 VPC
VPC means Virtual PC?
				griznet
VPC - Amazon's Virtual Private Cloud
				inten
This is not clear at all to me what you are trying to implement. Explain, scheme is welcome.
				griznet
Sure,
I have two virtual Private clouds existing within Amazon EC2
Cloud #1 and Cloud #2
I want a VPN connection from Cloud #1 to Cloud #2
[When I had previously set up a simple VPN Connection with a VM on Cloud#1 as the VPN Server, and a VM on Cloud#2 as a client, it would not work if I used a local bridge with the VPN Sever. In fact, I was told I could not use a local bridge)]
So I tried using a local bridge and VPN Server on both ends and no luck.
the private networks on both clouds are 10.0.0.0/16. Is that an issue? do they need to be different?
				inten
Please read this http://www.softether.org/4-docs/2-howto and choose and wirte the best conforms your idea.
