Is there a way to establish a lan to lan bridge using multiple wans?
This is for two concerns, one is reliability, it would allow seemless failover between wan links. The other is for full bandwidth utilization. It would be nice if streams / packets could be load balanced across 32 tcp sessions per wan to fully utilize available bandwidth.
This is similar to the peplink vpn bonding, but would be nice in your versatile software vpn solution.
Let me know if this is possible.
						Multiple wans
				dnobori
Re: Multiple wans
It is difficult to achive the requirement by using just one server per site.
However, you can realize it by using two servers per site, with STP-enabled L2 switches.
http://www.vpnusers.com/viewtopic.php?f ... =stp#p7032
