I have a problem with local bridge in Softether VPN server.
I want to set home VPN, where I will be able to connect to my home network from everywhere.
I use L2TP and SSTP function and there is the same problem. Windows default VPN client on my Windows 8.1 throws error 720 (in attachment). I found, that problem is in local bridge function - client does not obtain IP address and it throws error 720.
In my network is DHCP server, which allocates addresses (home router).
If I set IP on client manually (not from DHCP), client will connect, but is immediately disconnected (without any error). No communication is possible.
I tried also Softether client - there is connection without errors and IP address is assigned, but no stations are reachable (WAN, LAN too).
So, result is that local bridge between VPN server and Linux physical device "eth0" is not working.
I tried to install VPN server to my computer (Windows 7) and there was everything after configuration correct and functional. But same configuration is not working on cubieboard.
My configuration:
1. OS: Tried on Linaro(Ubuntu) and Fedora (same result)
2. ifconfig -a
eth0      Link encap:Ethernet  HWaddr 02:c9:07:c1:eb:73
          inet addr:192.168.1.6  Bcast:192.168.1.255  Mask:255.255.255.0
          inet6 addr: fe80::c9:7ff:fec1:eb73/64 Scope:Link
          UP BROADCAST RUNNING PROMISC MULTICAST  MTU:1500  Metric:1
          RX packets:65248 errors:0 dropped:5 overruns:0 frame:0
          TX packets:92869 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:8836663 (8.8 MB)  TX bytes:11571519 (11.5 MB)
          Interrupt:87 Base address:0x4000
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          UP LOOPBACK RUNNING  MTU:16436  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
tunl0     Link encap:IPIP Tunnel  HWaddr
          NOARP  MTU:1480  Metric:1
3. uname -a
Linux cubieboard2 3.4.61+ #1 SMP PREEMPT Sat Oct 26 16:09:42 CST 2013 armv7l armv7l armv7l GNU/Linux
4. Version 4.08 Build 9449
5. VPN server
6. NAT is set correctly and firewall is disabled.
7. No
						Local bridge not working on Arm Linux - cubieboard2
				NedCZ
Re: Local bridge not working on Arm Linux - cubieboard2
Could you check the server log?
Is host on LAN shown in MAC address table?
				NedCZ
Thank you for your answer.
I checked log and after some experiments, I found that promiscuos mode on my system is not functional.
Network card drop every packet, which has different MAC from MAC on physically interface.
The reason, why VPN connection is not completed succesfully, is my DHCP server on router.
Router does not send its DHCP responses to broadcast, but directly to specific MAC address.
So, DHCP response packets are dropped and IP address is not set - it raise this error (720).
I tried other DHCP server, which communicates via broadcast and then was connection without error.
But communication was impossible.
The problem is probably in drivers. There is new version for my network module. I dont know how to update driver, so I will try to find OS with actual kernel.
I will give here a result.
