OpenVPN
Loly
OpenVPN
Post by Loly » Thu Jun 26, 2014 8:22 am
Hello Dear all im new here!!
I got a problem how to resolve that problem?
i'm using softether OpenVPN clone server function. How to configure OpenVPN clone server function? and does OpenVPN clone server function must be using Certificate authentication? And how to config OpenVPN on Android, iphone, Microsoft mobile? Please help me please!!!
im trying openVPN connection but connection terminated and there is our server log
2014-06-26 16:03:06.030 On the TCP Listener (Port 443), a Client (IP address 172.11.117.158, Host name "172.11.117.158", Port number 49837) has connected.
2014-06-26 16:03:06.030 For the client (IP address: 172.11.117.158, host name: "172.11.117.158", port number: 49837), connection "CID-29" has been created.
2014-06-26 16:03:06.296 SSL communication for connection "CID-29" has been started. The encryption algorithm name is "AES256-SHA".
2014-06-26 16:03:06.499 Connection "CID-29" terminated by the cause "A client which is non-SoftEther VPN software has connected to the port." (code 5).
2014-06-26 16:03:06.499 Connection "CID-29" has been terminated.
mesa57
Re: OpenVPN
Post by mesa57 » Thu Jun 26, 2014 8:52 am
Generate an .ovpn configuration from you're server and import this in you're openvpn client (openvpn connect for example).
Make sure the openvpn (default 1194) is opened if you use a NAT router.
Connect to the Softhether openvpn server by specifying it's public IP adress or dns name. Specify the user and optional the the virtual hub to connect to (user@hub) and of source the password.
Thats all !
Loly
Re: OpenVPN
Post by Loly » Fri Jun 27, 2014 12:58 am
thanks for your help
i got a new promblem:
im trying connect android by openvpn
there is Certificate error: OpenVPN server certificate failed: PolarSSL: SSL read error X509 - Certificate verification failed, e.g. CRL, CA or signature check failed
how i do now?
Re: OpenVPN
Post by cedar » Fri Jun 27, 2014 2:34 am
There is workaround for PolarSSL problem in Build 9448.
Please update your VPN server and re-generate certificate.
http://www.softether.org/5-download/history
Loly
Re: OpenVPN
Post by Loly » Thu Jul 03, 2014 2:14 pm
Thank you for your help!
im configured:
"virtual hosts network interface"'s ip set to 192.168.216.240
dhcp server config range from 192.168.216.241 to 192.168.216.245
and Mask is 255.255.255.0
then there is client succesfully connected to vpn but client has wrong ip address it is 192.168.216.241 mask 255.255.255.252. and i trying ping to client ip address it is not not pinging. how to fix and config DHCP server?
Re: OpenVPN
Post by thisjun » Thu Jul 24, 2014 7:54 am
Could you give me more information?
OS or using SecureNAT or using localbridge etc.
Please see this page http://www.vpnusers.com/viewtopic.php?f=7&t=2790
