Fisrt off I would like to think everyone involved in this project. Setting it up to run on Windows 7 was so easy even I could do it, but my OS of choice is linux Ubuntu. I got the linux package, compiled and installed it easily enough and started it up with command
sudo ./vpnclient start
and got SoftEther VPN Client Service Started. I then used command
./vpncmd
and entered the SoftEther VPN Command Line Management Utility. At this point, everything was going smoothly. I created my virtual network adapters and used command
niclist
and got this:
NicList command - Get List of Virtual Network Adapters
Item |Value
Virtual Network Adapter Name|shangoVPN
Status |Enabled
MAC Address |00ACB048D410
Version |Version 4.09 Build 9451 (English)
Virtual Network Adapter Name|VPNGATE
Status |Enabled
MAC Address |00AC45A24648
Now this is where I run into problems. When I use the accountImport command
accountimport
I have no idea which file to point it to. Here are the files in my vpnclient folder
shango@shango-PC:~/vpnclient$ ls
Authors.txt Makefile
backup.vpn_client.config ReadMeFirst_Important_Notices_en.txt
chain_certs ReadMeFirst_License.txt
client_log vpnclient
code vpn_client.config
core vpncmd
hamcore.se2 vpngate_1939.ovpn
lang.config vpngate_1939.ovpn~
lib vpngate.crt
Linux shango-PC 3.13.0-24-generic #47-Ubuntu SMP Fri May 2 23:31:42 UTC 2014 i686 athlon i686 GNU/Linux
SoftEther VPN Client (Ver 4.09, Build 9451, Intel x86) for Linux
eth0      Link encap:Ethernet  HWaddr 00:11:22:33:44:55
          inet addr:1xx.x1.3x.xx3  Bcast:1xx.x1.3x.xx5  Mask:255.255.252.0
          inet6 addr: da80::210:24ee:ce81:148/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:2431 errors:0 dropped:0 overruns:0 frame:0
          TX packets:2454 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:1200845 (1.2 MB)  TX bytes:345824 (345.8 KB)
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          RX packets:868 errors:0 dropped:0 overruns:0 frame:0
          TX packets:868 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:89587 (89.5 KB)  TX bytes:89587 (89.5 KB)
vpn_shangovpn Link encap:Ethernet  HWaddr 00:ac:b0:48:d4:10
          inet6 addr: fe80::2ac:b0ff:fe48:d410/64 Scope:Link
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:500
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
vpn_vpngate Link encap:Ethernet  HWaddr 00:ac:45:a2:46:48
          inet6 addr: fe80::2ac:45ff:fea2:4648/64 Scope:Link
						SoftEther client and linux
				inten
Re: SoftEther client and linux
Guys, why don't you ever do this simple thing... RTFM?
https://www.softether.org/4-docs/1-manu ... on_Setting
Use this to import the VPN Connection Setting file that was exported by the AccountExport command and add it to the VPN Client.
And, generally, it would be good if you mentioned what are you trying to achieve in your experiment with SE.
Do you run a GUI version of linux?
				shango
Thanks inten, for your prompt, if somewhat sarcastic, reply.  I ask you to please refer to the frist paragraph of second sentence of post. I didn't know there was a manual... should have, but didn't. I have a whole folder of third-party how-tos' that I googled and I'm one of those people to whom you have to explain things as if you were talking to a rock, but I digress. I am an American and since we are basically becoming a police state with the law being a corporate strong-arm, I just think what I do in the privacy of my own home is nobodys bussiness but my own. A great philosopher once said 'I don't want nobody to give me nothing... open up the door and I'll get it myself.' Thanks for opening the door. Yes I run a GUI, Ubuntu-Desktop. Now off to read that  manual.
ShangoRasta
						ShangoRasta
				inten
Hi.
Nothing sarcastic with my reply went to you. Take a look, there are many questions here being left w/o an answer and the main reason is every question was answered at least once.
Check this http://vpnhpanel.com/sf/viewtopic.php?f=7&t=12, I suppose it will help you.
				shango
Please don't let my reply distract from my gratitude. I sincerely appreate you for taking the time to read , reply and for your help. I'm still reading the manual, and when I'm finished, I may be able to help someone else the way you have helped me. Thanks again inten.
shango
						shango
