I have installed SoftEther server behind FritzBox moder/router. I only forward TCP port 443 and
i can connect(Standard TCP/IP(IPv4)) with softether client, but UDP Acceleration is not active. When activate
DMZ(open all ports) on computer which is installed Softether then UDP Acceleration is active. Why?
Do i need to open some other port for UDP Acceleration?
UDP Acceleration
Re: UDP Acceleration
The port which is used for UDP acceleration is not fixed.
