First sorry about my english.
I have a problem with file transfer when I using softether as l2tp/ipsec vpn.
1. Info about server:
Description:	Ubuntu 12.04.4 LTS
Linux xxxx 3.2.0-57-generic #87-Ubuntu SMP Tue Nov 12 21:35:10 UTC 2013 x86_64 x86_64 x86_64 GNU/Linux
2. Info about network:
ifconfig -a
br0       Link encap:Ethernet  HWaddr 12:a3:e6:8d:4f:c6
          inet addr:172.18.45.5  Bcast:172.18.45.255  Mask:255.255.255.0
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:363825049 errors:0 dropped:0 overruns:0 frame:0
          TX packets:321434878 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:44647655288 (44.6 GB)  TX bytes:349997123181 (349.9 GB)
br0:1     Link encap:Ethernet  HWaddr 12:a3:e6:8d:4f:c6
          inet addr:172.18.45.6  Bcast:172.18.45.255  Mask:255.255.255.0
br0:2     Link encap:Ethernet  HWaddr 12:a3:e6:8d:4f:c6
          inet addr:172.18.45.10  Bcast:172.18.45.255  Mask:255.255.255.0
br0:3     Link encap:Ethernet  HWaddr 12:a3:e6:8d:4f:c6
          inet addr:172.18.45.7  Bcast:172.18.45.255  Mask:255.255.255.0
br0:4     Link encap:Ethernet  HWaddr 12:a3:e6:8d:4f:c6
          inet addr:172.18.45.8  Bcast:172.18.45.255  Mask:255.255.255.0
eth0      Link encap:Ethernet  HWaddr a4:5d:36:11:2e:95
          inet addr:188.138.xx.xxx  Bcast:188.138.xx.xxx  Mask:255.255.255.192
          UP BROADCAST RUNNING PROMISC MULTICAST  MTU:1500  Metric:1
          RX packets:697145128 errors:0 dropped:134 overruns:0 frame:80
          TX packets:778762782 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:463128545173 (463.1 GB)  TX bytes:546814395660 (546.8 GB)
          Interrupt:18
eth1      Link encap:Ethernet  HWaddr 68:05:ca:1e:89:8d
          RX packets:2489523662 errors:0 dropped:5101834 overruns:0 frame:0
          TX packets:1091739405 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:534010023360 (534.0 GB)  TX bytes:489088324345 (489.0 GB)
          Interrupt:16 Memory:fbfe0000-fc000000
eth2      Link encap:Ethernet  HWaddr a4:5d:36:11:2e:94
          BROADCAST PROMISC MULTICAST  MTU:1500  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
          Interrupt:17
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          UP LOOPBACK RUNNING  MTU:16436  Metric:1
          RX packets:46518 errors:0 dropped:0 overruns:0 frame:0
          TX packets:46518 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:19611331 (19.6 MB)  TX bytes:19611331 (19.6 MB)
tap0      Link encap:Ethernet  HWaddr 76:bc:23:ab:84:9a
          RX packets:4829495 errors:0 dropped:0 overruns:0 frame:0
          TX packets:70728186 errors:0 dropped:311 overruns:0 carrier:0
          RX bytes:784617939 (784.6 MB)  TX bytes:8231505005 (8.2 GB)
tap1      Link encap:Ethernet  HWaddr 26:cc:b7:da:25:f2
          RX packets:24410809 errors:0 dropped:0 overruns:0 frame:0
          TX packets:100220174 errors:0 dropped:5449 overruns:0 carrier:0
          RX bytes:3092858008 (3.0 GB)  TX bytes:40917253576 (40.9 GB)
tap2      Link encap:Ethernet  HWaddr 22:51:7c:59:70:7d
          RX packets:50267416 errors:0 dropped:0 overruns:0 frame:0
          TX packets:147167205 errors:0 dropped:7801 overruns:0 carrier:0
          RX bytes:5968587001 (5.9 GB)  TX bytes:100144429241 (100.1 GB)
tap3      Link encap:Ethernet  HWaddr ae:10:77:27:62:c3
          RX packets:65080840 errors:0 dropped:0 overruns:0 frame:0
          TX packets:152385679 errors:0 dropped:15728 overruns:0 carrier:0
          RX bytes:19023991024 (19.0 GB)  TX bytes:98250740445 (98.2 GB)
tap4      Link encap:Ethernet  HWaddr 5e:19:90:aa:17:0f
          RX packets:15161291 errors:0 dropped:0 overruns:0 frame:0
          TX packets:87589776 errors:0 dropped:1780 overruns:0 carrier:0
          RX bytes:2077782588 (2.0 GB)  TX bytes:27030621597 (27.0 GB)
tap5      Link encap:Ethernet  HWaddr 12:a3:e6:8d:4f:c6
          RX packets:22160744 errors:0 dropped:0 overruns:0 frame:0
          TX packets:97860579 errors:0 dropped:1567 overruns:0 carrier:0
          RX bytes:2878196549 (2.8 GB)  TX bytes:39396549102 (39.3 GB)
tap6      Link encap:Ethernet  HWaddr 7e:23:fe:43:a9:38
          RX packets:94446 errors:0 dropped:0 overruns:0 frame:0
          TX packets:65936623 errors:0 dropped:25 overruns:0 carrier:0
          RX bytes:10875606 (10.8 MB)  TX bytes:4033455894 (4.0 GB)
tap7      Link encap:Ethernet  HWaddr 96:a7:0d:30:be:dc
          RX packets:29068871 errors:0 dropped:0 overruns:0 frame:0
          TX packets:112341747 errors:0 dropped:9326 overruns:0 carrier:0
          RX bytes:4127431405 (4.1 GB)  TX bytes:59931967825 (59.9 GB)
br0 - root local interface connected to VLAN
br0:* - aliases local IPs for rinetd
eth* - bonding
tap* - OpenVPN instance
3. Softether build:
softether-vpnserver-v4.08-9449-rtm-2014.06.08
4. SoftEther VPN component:
L2TP over IPsec Server Function Enabled            |Yes
Raw L2TP Server Function Enabled                   |Yes
EtherIP / L2TPv3 over IPsec Server Function Enabled|Yes
5. This server have the firewall and all UDP ports open.
6. VPN Server/vpn>SecureNatStatusGet
SecureNatStatusGet command - Get the Operating Status of the Virtual NAT and DHCP Server Function (SecureNat Function)
Item                     |Value
Virtual Hub Name         |vpn
NAT TCP/IP Sessions      |47 Session
NAT UDP/IP Sessions      |20 Session
NAT ICMP Sessions        |0 Session
NAT DNS Sessions         |0 Session
Allocated DHCP Clients   |3 Client
Kernel-mode NAT is Active|No
VPN Server/vpn>SecureNatHostGet
SecureNatHostGet command - Get Network Interface Setting of Virtual Host of SecureNAT Function
Item       |Value
MAC Address|00-AC-34-21-35-B5
IP Address |192.168.30.1
Subnet Mask|255.255.255.0
About my problem:
This server using as IPsec/l2tp vpn server for users, all users connect to server and working via VPN but users with Linux (Mint, Ubuntu) have problems with disconnects and droped file transfer.
E.g. I'am connect from Linux computer to another linux server via SSH, work few minutes and get connection reset: Broken pipe
Also when I tried tranfer files from my comp to server or from server to me I'm get/put only few bytes and transfer frozen:
hellname@null /tmp $ rsync -av --progress test.img cc1.local:~/.
sending incremental file list
test.img
       32768   0%    0.00kB/s    0:00:00  ^C
rsync error: received SIGINT, SIGTERM, or SIGHUP (code 20) at rsync.c(549) [sender=3.0.9]
test.img
     2129920   1%    1.79MB/s    0:01:11  ^C
I'm tried tune sysctl parameters but not effect. Can you help me please? I.f you need more information about my problem, server or other please tell me. Thanks a lot.
						Problem with file transfer via ssh and linux clients
				hellname
				hellname
Re: Problem with file transfer via ssh and linux clients
Something else, users that run on Windows no have problems.
				hellname
Somebody help me please with my issue.
				hellname
I solved my problem. Setup softetervpn without secureNAT and enable Local Bridge. Currently l2tp work fine.
