Hi.
I am computer programmer. (VS 2013 C#)
I do have a project .
In this project through the program with a single click to connect to the VPN server and the connection I have to stop again .
Server IP : 10.10.9.17
User : sony
Password : sony
Port Number : 443
Virtual Hub Name : VPN
Virtual Network Adapter to Use : VPN Client Adapter - VPN
Auth Type : Standard Password Authentication
Proxy Type : Direct TCP/IP Connection (No Proxy)
Can you give me a sample code with vpncmd.exe ?
Thank you.
On Click vpncmd.exe Connect and Disconnect
hk1978ank
Re: On Click vpncmd.exe Connect and Disconnect
I think you are right.
What problem does occur?
hk1978ank
No problem :))
juniored
Thanks.
It isn't explicit on manual of Softether cli avaiable on website.
this usage doubt should be inserted on FAQ session.
