Hi everyone,
I was looking for a secure remote desktop connection software to get connected over internet to another pc and i was advised to use SoftEther, but since i am not an expert i need to know first which version i need and if this software is for advanced users or it is user friendly?
I appreciate very much your support, thank you!
What version of SoftEther do i need to download?
Gaftalik
sdevries.otn
Re: What version of SoftEther do i need to download?
I'd recommend the latest version for now: SoftEther VPN 4.11 Build 9506 Beta (October 22, 2014)
Because of the SSL 3.0 / poodle vulnerability. This version can disable SSL, and force TSL.
http://www.softether.org/5-download/history
Gaftalik
Thank you for your answer.i thought for each need there is a different version.i will follow ur link and give it a try.
Thank u again!
Thank u again!
