I have followed setup instructions in the SoftEther documentation to configure SoftEther VPN Server on a remote virtual Windows server. A Local Bridge is configured on the virtual Ethernet (Microsoft) LAN adapter. On this remote virtual Windows server, RDP server is running. The goal here is to use SoftEther VPN to restrict access to the RDP services, allowing SoftEther VPN Clients only to access the server via RDP.
I have a SoftEther VPN Client configured on a local machine to allow bridging. The VPN Client displays that it successfully connects to the VPN Server. However, on the local machine, the VPN virtual adapter shows "no network access" for IPv4 and IPv6. Further, I don't understand how to get the local machine to connect to the remote server via RDP via the VPN's local network. How do I figure out what the server's (and hence the RDP server's) local IP address is? The server's local IP address is not shown anywhere; in all SoftEther dialogue boxes, reports, lists, etc. it is always shown as the public IP address.
What am I doing wrong?
how to conect to server via server's local IP through SoftEther VPN client?
sevpn
sevpn
sevpn
Re: how to conect to server via server's local IP through SoftEther VPN client?
Giving up on SoftEther for now.
raafat
What is the original goal that you're seeking for? If you need to restrict access on a specific adapter you could use firewall on Windows machines so that you only allow the ports that you want to pass. Such as the ones that used by the Remote Desktop Connection program. Let's know more about your goal.
sevpn
Hi raafat - thanks for replying.
Yes, obviously I have all ports blocked on the firewall for RDP except 3389. My goal is to also block port 3389 to the public (via firewall) and only allow access to users who have authenticated to the server's local (domain/local) network.
So I'm just wanting to use SoftEther in its most basic configuration: Giving remote users local access to a server via VPN. The most basic use case.
The problem is:
- I have followed setup instructions in the SoftEther documentation to configure SoftEther VPN Server on a remote virtual Windows server. A Local Bridge is configured on the virtual Ethernet (Microsoft) LAN adapter. On this remote virtual Windows server, RDP server is running.
- I have a SoftEther VPN Client configured on a local machine to allow bridging. The VPN Client displays that it successfully connects to the VPN Server.
- However, on the local machine, the VPN virtual adapter shows "no network access" for IPv4 and IPv6.
- Further, I don't understand how to get the local machine to connect to the remote server via RDP via the VPN's local network. How do I figure out what the server's (and hence the RDP server's) local IP address is? The server's local IP address is not shown anywhere; in all SoftEther dialogue boxes, reports, lists, etc. it is always shown as the public IP address.
The problem is:
You should set up a VPN server on local site.
http://www.softether.org/4-docs/2-howto ... M_into_LAN
