Portforward
raafat
Re: Portforward
Hello there! It's not clear to me what you are trying to accomplish. It would be much better if you can elaborate further on it. Also, if you really know what you are trying to do and you need to forward ports on a local machine, I assume you use a Unix-like systems, you could use "iptables" for that purpose. Check out this link: https://www.digitalocean.com/community/ ... h-iptables for further details.
Re: Portforward
What OS did you use on the local server?
What VPN component did you install on the local server?
