hi, would like to ask how do we Reset(to 0) both the Transfer Bytes and Transfer Packets for each user? as we like to monitor their monthly usage and reset it after month end.
am using SoftEther 64bit 4.22 build 9634 on Windows Server
thank you,
Reset Transfer Byte/Packets
raafat
Re: Reset Transfer Byte/Packets
Hello there! Here is one possible solution but you may consider it a little dirty. Anyway, you could delete that user and then create it back. If you use a script for that, it would happen in less than a second or a couple. Also, you can investigate further on this for yourself.
