Anyone else seeing issues with using openvpn and Version 4.23 Build 9647 of SoftEther?
All worked before I upgraded from SoftEther VPN 4.22 Build 9634 to 4.23 Build 9647
Using the SoftEther VPN Client works just fine as before, but once I try to connect my Android phone with openvpn the following is logged
2017-10-20 10:48:21.013 OpenVPN Session 2 (xxx.xxx.xxx.xxx:xxxx -> xxx.xxx.xxx.xxx:xxxx): A new session is created. Protocol: UDP
2017-10-20 10:48:21.013 OpenVPN Session 2 (xxx.xxx.xxx.xxx:xxxx -> xxx.xxx.xxx.xxx:xxxx) Channel 0: A new channel is created.
2017-10-20 10:48:21.023 OpenVPN Session 2 (xxx.xxx.xxx.xxx:xxxx -> xxx.xxx.xxx.xxx:xxxx) Channel 0: A new channel is created.
2017-10-20 10:48:23.318 ------------------------------------------------------
2017-10-20 10:48:23.318 SoftEther VPN Server Version 4.23 Build 9647 (English)
2017-10-20 10:48:23.318 Compiled 2017/10/18 17:22:59 by yagi at pc33
2017-10-20 10:48:23.318 Log Messages are written with UTF-8 Encoding Format.
2017-10-20 10:48:23.318 The SoftEther VPN Server has been started.
2017-10-20 10:48:23.318 IPsec Module: The IPsec ver 2.0 (ISAKMP/IKEv1) processing module is started.
2017-10-20 10:48:23.318 OpenVPN Module: The OpenVPN Server Module is starting.
2017-10-20 10:48:23.338 Loading the configuration file.
2017-10-20 10:48:23.469 Monitoring the directory "/usr/local/vpnserver". If the amount of available free disk space becomes less than 100.00 MBytes, the backup files for log files and configurations that are saved on the sub-directories of this directory will be automatically deleted in the order of oldest first. The amount of free disk space that determines when to start deletion can be modified by changing the "AutoDeleteCheckDiskFreeSpaceMin" item in the configuration file.
2017-10-20 10:48:23.479 Virtual Hub "xxxxxxxxxxxxx" has been started.
2017-10-20 10:48:23.479 The MAC address of Virtual Hub "xxxxxxxxxxxxx" is "XX-XX-XX-XX-XX-XX".
2017-10-20 10:48:23.479 [HUB "xxxxxxxxxxxxx"] The Virtual Hub is now online.
2017-10-20 10:48:23.479 TCP Listener (port xxxx) is starting.
2017-10-20 10:48:23.479 TCP Listener (port xxxx) has started. Now listening for connection from client.
2017-10-20 10:48:23.559 [HUB "xxxxxxxxxxxxx"] The Local Bridge connection "eth1" has started. The bridge session "SID-LOCALBRIDGE-1" was created.
2017-10-20 10:48:23.559 The configuration file has been loaded.
To me it seems that the server just crashes and reloads?
Any ideas? In case it matters, I am running my server on Raspberry Pi 3 Model B.
*EDIT*
I just now tried to connect to a cloned server with same settings but version 4.22 Build 9634
Same Android phone, same openvpn client, all works, no crash.
Looks to me like there is something wrong with openvpn and 4.23 Build 9647.
openvpn crashes SoftEther VPN server
softethervpnuser1
Re: openvpn crashes SoftEther VPN server
I think you know already, there is update version of SoftEther.
Please check it.
http://www.softether.org/5-download/history
Please check it.
softethervpnuser1
I see that now, had not noticed it before.
I will try that in the coming days and see if that helps.
softethervpnuser1
Just wanted to inform it worked when updated to 4.24 Build 9651
Thanks for the heads up!
