After working a bit with the Window Client Manager, it happens to me that it does not work anymore. To restore the situation, you need to restart the vpnbridge module of the server. Looks like the problem is in the vpnbridge module, is true?
has it happened to others?
the server ethervpn is installed in a CentOS Linux release 7.4.1708 (Core)-3.10.0-693.2.2.el7.x86_64 #1 SMP
vpnbridge crash
Giuliano
Re: vpnbridge crash
ok all my problems I've solved by recompiling the latest version of SoftEther VPN 4.24 Build 9651 Beta (October 23, 2017).
thak you.
thak you.
