SoftEther VPN 4.24 Build 9651 Beta (October 23, 2017)
I have upgraded to this and all android clients are not working now...it is saying unsuccessful
the login is not even hitting the server logs.
any clues?
android vpn not working after build 9651 upgrade
vinchu
fenice
Re: android vpn not working after build 9651 upgrade
Are you using a specific client or the inbuilt android vpn? If not, why try OpenVPN Client, at least with that you'll get logs and some indications of the problem. FWIW, I use the OpenVPN client and I've recently upgraded to the most recent SoftEtherVPN version and connect without problems. Have you tried connecting locally with the SoftEther Server Manager and does that work or perhaps just a telnet to the correct server port?
vinchu
Thanks for your reply
All iOS and MacOS clients work, just not on Android
Yes we use inbuilt android VPN - I believe it is some teething problem with new version of SE.
[quote=fenice post_id=55008 time=1509975104 user_id=10754]
[/quote]
[/quote]
What version of SoftEther VPN server did you use before upgrade?
vinchu
SoftEther VPN 4.22 Build 9634 Beta (November 27, 2016)
fenice
Have you considered upgrading to the latest release?
hidesan
I encountered the same issue.
My solution is very simple, downgrading to 9634 from 9651.
Then, the vpn connection recovered with Android8.0 and iOS11.
